Old 12-12-2015, 10:23 AM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: G/PS Mustang GT
Originally Posted by black88coupe View Post
Thank you. It would be great to have a class car but unfortunately its not in the cards for me. That's why I refer to mine as the wanna-be PS car. Its not the fastest thing but I'm having fun with it. 2016 will see some mild engine upgrades but nothing crazy. Also, I'll be moving some weight around as well to hopefully dial in my setup a bit more. Again Thanks. Mitch
Mitch
What have you done so far?
What do you need to run Pure Stock competitively?
D
Old 01-22-2016, 12:58 PM   #12
mark weymouth
Some progress on the project, it is about ready for spring testing.
Name:	IHRA Mustang GT 23.JPG
mark weymouth is offline   Reply With Quote
Old 01-22-2016, 01:10 PM   #13
Old 01-22-2016, 07:34 PM   #14
Dan Fahey
Dan Fahey's Avatar
Sweet!
Old 01-22-2016, 10:30 PM   #15
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Mitch
D
Sorry Dan just saw your post.
My current combo:
1985 GT Mustang
1988 EEC4 speed density system
Intake EGR blocked off
120,000 mile stock motor with Cobra roller rockers and under drive pulleys
Full aftermarket exhaust
Aluminum rad/ electric fan
AOD with some upgrades. Eliminated lockup.
2400 stall converter
Aluminum driveshaft
4.10's
Strange adjustable front struts
Team Z rear upper/ lower control arms w/ air bag
Fiberglass cowl hood
Manual rack/ pinion
Lowering springs
Future plans:
Moving the battery to the back to help even out the front to rear weight.
Ported GT40 heads with an Explorer intake later this season. I'm planning on running the stock cam for awhile to see what I can squeeze out of it.
I'm planning on some cosmetic changes over the winter such as later model qtr. windows and later model dash. The car will kind of be a little bit crossbred appearance wise.
The car goes 13.6X @ 99.5 the way it sits. It WILL go faster this year with very few changes. Possibly if I left the stock 1985 dash and quarter windows and put a stock hood back on it I could pass tech. Not 100% sure about that though. I don't think there are any races near me except maybe Norwalk. Not sure if US131 hosts anything I would have to see the schedule.
Mitch Beri- The Motor City
Old 01-22-2016, 10:37 PM   #16
black88coupe
Looks great!
Old 10-07-2016, 10:38 AM   #17
mark weymouth
Unfortunately life stepped in and clogged up the entire summer and fall. I missed my normal races, and after putting the little G/PS back together I have been itching to get out. While checking out that everything was back together correctly on a mellow test drive third gear decided to leave and make a mess of the trans. It didn't have that many passes on it but as we all know the T5 isn't robust. A new GForce WC T5 with more durability is installed. I had to change the gear set as the 3.35 cluster isn't available in the stronger trans.
I am finally ready to get out and test the freshened motor, new trans, and the few other upgrades. I need to find a new baseline for the car with the changes. Testing fuels too. The goal is to find the proper new launch and shift points. See if the tire psi's still stand, see which fuel the car likes best and find if the base timing is still best. The previous best ET is a 12.801 @ 104.xx, the goal is to go under it.
Wish us luck while we go have fun at Mid-Michigan on Sunday.
Old 10-12-2016, 08:04 AM   #18
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Nice PS build.
Very clean looking setup.
Wish you luck on your testing and remember, we love pics and time slips
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
