Old 12-25-2007, 01:22 PM   #11
FED 387
Liked 335 Times in 182 Posts
Default Re: AN Line for lower radiator hose
AFCO makes the threaded hose adapters about $20-25 each depending on the size---Comp 387
Old 12-25-2007, 02:42 PM   #12
frank v
dave , dont be cheap. go get the bung welded in the rad . i have -16 line in my car for upper and lower hoses.
s/g 1620
frank v is offline   Reply With Quote
Old 12-26-2007, 09:10 AM   #13
Dave Steltz
Dave Steltz's Avatar
Frankie...as my southern bud would say "It aint easy being cheap !"...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 12-26-2007, 10:14 AM   #14
krugracing12
Dave
My new car has a stock sized pipe, custom bent with extra elbows to fit around all the stuff in the way. It is thin wall tubing, powder coated to match the chassis with 2 short connector hoses to the stock out/inlets. I did not make it, but it reminds me of a weld together header kit. you might be able to make one out of muffler tubing and save $$. On gas below 85 degrees my car cools down while driving back to the pits.
Bill
krugracing12 is offline   Reply With Quote
Old 12-26-2007, 02:48 PM   #15
Bryan Gillespie
Banned
True That!
Bryan Gillespie is offline   Reply With Quote
