#51 |
Liked 799 Times in 236 Posts
Rich, what did you find out concerning your chassis deal? -Al
"That'll never work....." |
#52 |
Liked 3,007 Times in 721 Posts
Rich, it sounds like everything was done correctly. This definitely falls in the weird category. Good luck and let us know how it comes out.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
#53 |
Liked 33 Times in 16 Posts
I still am not sure what the reason is, but I did shim the two body mounts closest to the rear on the driver side. At the front door hinges there is only a 1/4" difference so I elected to not shim any further forward of the frame. I'll have a better sense of what it looks like once all the weight is back on the car and I can get it outside for a better view.
Rich Taylor I/SA - 321 |
#54 |
Been taking care of minor details lately. I discovered that wet sanding much improved the appearance and just finished the entire vehicle...whew!
![]() ![]() Dash complete...doing some extra wiring before it goes back in. ![]() ![]() ![]() Engine is already in place...will attach the metric transmission the next time I pick the truck up in the air. It's a toss up which will be the final step...setting up the rear housing or installing the vent/side glass. I'm just dreading trying to get that glass back into place. ![]()
#55 |
All glass, trim and bumpers installed...finally looks like something again.
#56 |
Liked 520 Times in 132 Posts
Nice car! Engine looks like its painted same color we painted ours I like it!
#57 | |
#58 |
Finished the doors today and pulled out the manual pedals in favor of an automatic brake pedal. Metric 200 went right in with the factory cross member...guess I will shell the 12-bolt tm. Junk headers installed until I can find a suitable set.
#59 |
Spent the day doing some much needed cleanup and organizing instead of actual work on the El Camino. I also moved operations over to the heated side of the building with the onset of colder temps...mo happy.
![]() ![]() We really need to get the '66 back together for next year. ![]()
#60 |
Moving at a snail's pace as usual. Ford housing ends to be welded in place Friday, then I can order axles and get the 12-bolt back under the truck.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 12-22-2016 at 12:44 AM. |
