Old 11-29-2016, 08:54 AM   #11
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: How far under index?
My definition of "competitive" in Stock Eliminator is whatever it takes to qualify @ the US Nationals, usually .850 or quicker under.
A Stocker running .850 or more under stands a decent chance of qualifying at any event once you pay your entry fees.
Now, class eliminations....that's another story.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-29-2016, 09:31 AM   #12
Randall Klein
Liked 316 Times in 67 Posts
How about .01 OVER the index. Except for INDY and heads up, 3 under to .01 over is about the same (given that .01 over can be done in poor conditions)
Of course you have to dial the index, but you eliminate breaking out to some degree
I've had 2 races (at Topeka's wind tunnel) where my opponent could not run the index but had to dial it. Made me very nervous as they could run all out
Just another view
Old 11-29-2016, 10:07 AM   #13
HR9121
HR9121's Avatar
With the exception of Indy all National events have quotas below a full field so qualifying is a non issue granted you can run the index and have enough grade points to enter. Like the others have said I wouldn't worry too much about heads up runs in your class not a very populated class like A-D/SA.
James Williamson
W200 J/SA. SS/JA
Old 11-29-2016, 10:32 AM   #14
Todd Hoven
Guest
Posts: n/a
Build it, run it, and enjoy! Welcome to stock. Get under it under the index and go from there.
Old 11-29-2016, 11:49 AM   #15
Rusty Davenport
Liked 101 Times in 27 Posts
Originally Posted by Bob Gullett View Post
In the 12 years since I put a stick in mine other than class run offs I've had one heads up race. There are very few G/S cars. The odds are very slim you will have a heads up. Put it together and go out and have fun.
I can't over state what Bob is saying........there are people that can't sleep at night because they spent their last dime to be a tenth faster, we don't need any more drama in class racing, if you are a hobby sportsman enjoy being that, keep the money in your pocket and spend it on a nice steak with some friends after qualifying.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 11-29-2016, 01:11 PM   #16
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Now, I think THAT's some good advice right there !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 11-29-2016, 01:15 PM   #17
Todd Hoven
Guest
Posts: n/a
X2!
Originally Posted by rusty davenport View Post
i can't over state what bob is saying........there are people that can't sleep at night because they spent their last dime to be a tenth faster, we don't need any more drama in class racing, if you are a hobby sportsman enjoy being that, keep the money in your pocket and spend it on a nice steak with some friends after qualifying.
Old 11-29-2016, 01:39 PM   #18
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
If it will run index, be consistent and you can cut a light you are ready to spend the money to enter a divisional or national. Otherwise you are only wasting your money to enter a race. Test, test, test until you have the car and you sorted out. If you run into a heads up so be it, otherwise why build a class car? If the car, clutch and trans are setup right you can be consistent too.
Good luck and have fun!
Sean Marconette
84 Mustang
5060 SS/N
Old 11-29-2016, 01:50 PM   #19
Liked 11,000 Times in 2,263 Posts
Don't forget about the Sports Nationals they only take the fastest 128 in stock and super stock.
Old 11-29-2016, 02:11 PM   #20
jmcarter
jmcarter's Avatar
Liked 3,244 Times in 986 Posts
As Larry indicated plus the Vegas Divisional in November had a full field and some pretty quick cars were on the sideline after qualifying...but if you're in Tampa then Vegas might not be in your plans. One big advantage of a stick combo is the lower likelihood of a heads up but in any case if you plan on going up to Bristol in the heat then you better be .4 under in order to run the index (no altitude adjustment for Bristol anymore). World of difference in cost to build a .2-.3 under car than a 1.0 under one.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
