Old 12-01-2016, 10:37 PM   #31
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Default Re: How far under index?
Originally Posted by Jeff Teuton View Post
Fatherly advice from someone with not enough sense to quit. Run your car, lots of little things you can do without major expense. Get a golf cart. Bring beer ( or your choice). Race, have fun, take the cart, ride around , lie about how much hp you got and how your opponent is cheating, drink beer. Sleep well. Repeat as necessary.
I like this guys AGENDA. Jeff bring that 69 1/2 out once in a while!!!
Frank Bialas 1570 STK
Frank Bialas is online now   Reply With Quote
Old 12-01-2016, 10:42 PM   #32
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by Darrel Goheen View Post
When there isn't another car in your class you get put in with other cars that also don't have another car in their class. You are both dialed by your indexes. Whomever crosses finish line first wins (providing no red light).
... also, one combo for sticks, one for automatics..
Mike A114
P/SA
Old 12-02-2016, 01:45 AM   #33
Chris Barnes
I hope I'm not giving away secrets or making anyone mad by saying this:learn everything you can about qualifying to the 1000' line. Qualify as slow as you can then pick it up if you need to. With a decent log you can extrapolate enough to dial in to the quarter from your 1000' data. It took me a couple of years to start doing this but as the owner/builder/driver of a .6 under C/SA car I can assure you that it made all the difference. Your experience will be different with a rare stick car I'm sure but every race I go to has at least one car that can "eat my lunch" heads up and you better believe they're gunning for me! I'm just a guy on a budget trying to have fun with my old Max Wedge and it's really all good when I'm racing but I need every advantage I can think of that doesn't cost a bunch more money. Finish your car and come on in, the water's fine!
Chris Barnes is offline   Reply With Quote
Old 12-02-2016, 01:52 AM   #34
Everett Vassar
Liked 2 Times in 2 Posts
I'm just impressed you used the word Extrapolate!
Everett Vassar is offline   Reply With Quote
Old 12-02-2016, 08:48 AM   #35
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
"Extra-polate" Does that have to do with dentures?
Old 12-02-2016, 08:52 AM   #36
Bryan Worner
Liked 535 Times in 86 Posts
Originally Posted by Freddie View Post
I know at National events qualifying is based on how far under the index you can go, but how far under do you really need to be to be competitive?
I only ask because I am finishing a long overdue project 1997 Mustang Cobra with the "Freshened" 4v and a 5 speed for Stock. Plan on running either F or G/S and while I may only be able to run some divisional events this year, my question is what should I be looking for to be able to qualify at most National events as well?
We have done quite a bit of work to the car inclusive of all the legal and accepted chassis mods, and have it right at weight, with a beefed up rear, good axles and a gear we think is right for now. I know a 5 speed car is at a disadvantage over the automatics but this is what I have to work with and I LOVE driving the 5 speed.
So again looking for a little help with how fast I should really be, and how do they run class eliminations now, its been years since I did this.
Freddie, my advice is use Dragracecentral.com as your friend. Go back to all of the events you would plan on attending, look at the stock qualifying and class runs. Even look at eliminations. That will tell you who runs in your class(s). and how fast they are.
Bryan Worner is offline   Reply With Quote
Old 12-02-2016, 12:42 PM   #37
Liked 5,138 Times in 1,961 Posts
Bryan is correct , and I'm surprised no one had brought it up.
The info you are seeking is not exactly a secret.
I am curious as to how you are going to use a 5-speed. I assume the one it comes with?
Old 12-02-2016, 03:43 PM   #38
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
I have been looking at several options for 5 speeds. There are a few good OEM Ford units available, like the T5 with Liberty gears and internals, G-Force also does a well built OEM T-5, then there is also the TREMEC series of trans were availalbe in many Mustang GT's.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-02-2016, 07:30 PM   #39
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
^^ This
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-02-2016, 08:47 PM   #40
ALMACK
ALMACK's Avatar
3 options if you use factory 5 speeds...T5, T45, and Tremec3650
A beefed up T5 or T45 with a modulaqr blowproof bellhousing might work.
Astro Performance can build one.
Hanlon Motorsports can build one with Liberty internals.
Up until this year, there were a lot of Coyote Stock racers in the NMRA using a beefed T5 behind a 5.0 Coyote modular crate engine running mid 10's.
If you go with a 2002-2004 Tremec 3650 that came in the Mustang GT those years it will require a Hanlon Motorsports adater to fit it to a sfi bellhousing like the Quicktime bellhousing.
I/PS '95 Mustang GT
