Old 12-03-2016, 08:45 AM   #1
Pony Pilot
Default Annual Slick Selection Debate
I've been running the Goodyear D1984 slick for over 10 years. I don't really have an issue with them, but every year I wonder if another tire might be better. Then I usually chicken out and go back to what I know. My car is an 800hp SST Mustang, 2830 lbs. I like a stiff sidewall for reaction time, and am now looking at the Hoosier 18260 tire. The biggest difference I see is the 1984 is a relatively hard compound and the Hoosier is soft. I was wondering if any of you have experience with both tires and what your opinions are regarding wear, 60 ft consistency, and ability to hold air to run tubeless. At $300+ a piece either way, a bad decision is somewhat pricey!
Pony Pilot is offline   Reply With Quote
Old 12-04-2016, 10:32 PM   #2
nomad
Liked 7 Times in 4 Posts
Default Re: Annual Slick Selection Debate
I had used the GY 1672 fir years. I recently changed to the Hoosier 18260. I'm happy I made the change.
nomad is offline   Reply With Quote
Old 12-05-2016, 01:05 PM   #3
cmracing
Liked 62 Times in 29 Posts
Hoosiers are about the only brand of tire I have ever run that don't need tubes to keep air in them..................
No rim screws, no bead locks, 20 psi in my 29.5x10.5's and no issues. Little less power than you, only 9.50@142 @ 3300lbs.
cmracing is offline   Reply With Quote
Old 12-12-2016, 03:43 PM   #4
Wilson1
I would encourage you to take a close look at MT’s. I have run both Hoosier and GY, and both are good tires. Yes the MT’s do leak air, even if you soap them before mounting, but they are more consistent and grip well in almost all conditions. The leaking air is not beg deal, just check your car every week if it is sitting and put a few pounds in them. I have been running the stiff sidewall 3074’S and the 3084’s and the 60’ couldn’t be more consistent. Talk to some of the guys running MT’s at your local track and see what they say. Trust me, you won’t be sorry.
Wilson1 is offline   Reply With Quote
Old 12-14-2016, 09:32 PM   #5
1968 SS
1968 SS's Avatar
Smile Re: Annual Slick Selection Debate
M/T have fixed their leaking side walls. 3084s is the tire you want and the only tire you need in a X8 or L8 compound!
1968 SS is offline   Reply With Quote
Old 02-06-2017, 03:07 PM   #6
EricArrow
EricArrow's Avatar
Take a look at the Hoosier 18245. Same contact patch as a 14x32 and has a stiff sidewall. I've had great luck with them.
Low and Slow
EricArrow is offline   Reply With Quote
