Old 12-05-2016, 11:23 PM   #11
SSDiv6
Default Re: Lifter rule in Stock
This is the actual language on the 2017 rule change.
It's not clear enough and it needs to be explained better.
It does not say that hydraulic lifters can be replaced with solids.
It still gives the requirements for checking hydraulic lifters.
Name:	2017 Cam Rule Change.JPG
Old 12-05-2016, 11:39 PM   #12
Casey Miles
Liked 508 Times in 92 Posts
If I misunderstand this change, sorry! The guys who use solid lifter engines are getting screwed over do to no chance on manipulating the lifters. It's bad enough that .010 in a hydraulic is considered OK by NHRA. The engines HP were based on the lifter working the way the manufacturer designed it, not the way they are now with a built in lash. Might as well let everyone use solid roller cams and get over with it.
Casey Miles
248H Stock
Old 12-05-2016, 11:50 PM   #13
Liked 5,137 Times in 1,960 Posts
After re-reading this, I think it gives the okay for ceramic bottom lifters, ..about 15 years after the fact.
I'll have to call my law firm , Dewey, Screwum , and Howe, and get an interpretation.
Old 12-06-2016, 12:14 AM   #14
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: Lifter rule in Stock
It also still says you must use OEM rocker arms or adjustable push rods (not both)????? The roller rocker OK has been law for several years? Jim
Old 12-06-2016, 12:36 AM   #15
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Casey Miles
248H Stock
Yes Sir ! Get it over with, solid roller cams need to be allowed, Look cars built after 1985 almost all have roller lifters, that's over thirty years ago and the (getting smaller) number of the older cars are almost fifty years old now, at this point with all the rule changes in stock to the valve train what difference will roller lifters really make .
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 12-06-2016, 08:19 AM   #16
Liked 1,907 Times in 427 Posts
Yeah, give everybody solid rollers.
Then next year, give everybody 0.700" lift.
A couple years down the road, wonder why you have a 9" tire Super Stock class, spiraling out of control.
Old 12-06-2016, 08:25 AM   #17
goinbroke2
Liked 405 Times in 158 Posts
Alan, I was thinking the same thing...stock lift but any duration...and roller rockers....and now solid lifters...and.....
All them "hyd" motors are going up in rpm now!
Old 12-06-2016, 08:41 AM   #18
Billy Nees
A couple years down the road? That ship sailed a long time ago.
Billy Nees 1188 STK, SS
Old 12-06-2016, 09:21 AM   #19
Jim Kaekel
Liked 535 Times in 110 Posts
X2. If you want roller lifters, go buy or build a SS car!
Jim Kaekel 3836 STK
Old 12-06-2016, 11:47 AM   #20
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Lifter rule in Stock
All I saw in the rule revision was an amendment allowing what has been accepted for years. Ceramic based lifters or coated tool steel lifters are not new,as we all know.If your combo came OEM with rollers, use rollers. If it didn't, does this language imply or specify a change over? I didn't read that.Accepted lifters for the last 10-15 years,be they ceramic based or coated steel, were still an OEM configuration. Running even OEM valve trains with lash isn't new either. What does this revision possibly change?
