Old 12-08-2016, 10:39 AM   #51
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Lifter rule in Stock
Originally Posted by Grey Ghost View Post
Here we go. Why do the hyd cam combos get an "up grade" and not the solid cam combinations?? IF ( I am not advocating for this) everyone had been up graded to rollers would that not have leveled the playing field? Am I missing something here? Are not the lifter concerns "wiping out a motor" shared with solid and hyd cams?
Hi Phil.
In a way, a hydraulic cam switched to solids actually loses lift when checked the NHRA way. Since the NHRA checking clearance is .000 (zero), a solid cam loses the lift from the lash when it's running.
A hydraulic lifter is theoretically always at .000 (zero) when it's running.
"That'll never work....."
Old 12-08-2016, 10:44 AM   #52
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
So in a sense, all the folks using a hyd lifter, as they were supposed to, can change to solid lifter grind, at the same specs, and gain, what maybe 25 to 30 hp ? Is that idea still correct ?
Im only out of class racing, for a little while...
2894 STK
Old 12-08-2016, 10:45 AM   #53
Coleydog
Liked 53 Times in 38 Posts
Seems like a lot of concern about someone getting an edge by using solids making them faster. If they run heads up, maybe, other than that it's a bracket race. Take away the heads up, run on your number, problem solved with Daddy WarBucks mega dollar engine getting a free ride.
Old 12-08-2016, 10:59 AM   #54
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Hi Phil.
Good Morning Al.
I understand that. Why the rule change then? Higher RPM capability?
Phil Vos
Grey Ghost is offline   Reply With Quote
Old 12-08-2016, 11:09 AM   #55
Alan Nyhus
Good Morning Al.
One less thing for Tech to check, would be my guess?
Old 12-08-2016, 01:39 PM   #56
ron mattson
Liked 68 Times in 31 Posts
My guess would be for ease of tech, the performance
Will change very little , not gonna turn a 6500
Rpm engine into a 8500 or gain a bunch of power.
I would think at very best .03-.05 the current generation
Of limited travel "hydraulic" lifters are solids already!
Just my .02$$ lol!!!!
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 12-08-2016, 02:18 PM   #57
pfordamx
Liked 7 Times in 5 Posts
Does this mean that Hydrualic rollers can be replaced with Solid Rollers?
pfordamx is offline   Reply With Quote
Old 12-08-2016, 02:24 PM   #58
ron mattson
Not sure in the roller stuff, but that is where
You would see the largest gain not flat tappets.
Old 12-08-2016, 03:15 PM   #59
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
x2
Bob Bender 144 O/SA
Old 12-08-2016, 03:45 PM   #60
Mike Keener
Liked 24 Times in 13 Posts
Great question!
Mike Keener
A/S B/S
C/SM
Mike Keener is offline   Reply With Quote
