Old 11-28-2016, 02:19 AM   #171
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Originally Posted by HawkBrosMav View Post
You going to make it by Jan 28th?? I hope your luck turns around, I know how bum ankles are and don't wish that upon anyone!
Brad
Yeah, I expect I'll join you guys part way through the season. I'm looking forward to it though, it sounds like a great program.
Dave Muller is offline   Reply With Quote
Old 12-04-2016, 08:46 PM   #172
Dave Muller
I'm still not up to doing any work under the car (getting up and down like that really seems to annoy my foot), but I was able to get a little done this weekend.
I finally got the pressure switch and got it installed into the brake line:
And I have the red engine closer to being ready to run. I do still need to pull the distributor again. It seems that this intake manifold has been severely milled. I suspected as much when the bolt holes didn't line up very well with the heads, and it was confirmed when I put the distributor in, and it bottomed out on the oil pump while still 1/8" off the gasket and manifold. And it was confirmed when I examined the back edge of the manifold and compared it to the black engine. So I'll have to get a shim to raise it up a bit.
Old 12-05-2016, 08:50 AM   #173
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
If that intake has been cut is it still legal?
U/SA
79 Mustang
Old 12-05-2016, 11:10 AM   #174
Dave Muller
Well I don't see anything in the rules that says it isn't. But I probably won't run this manifold in competition anyway, as I think the alignment between manifold runners and ports isn't very good. And the other manifold doesn't look milled to me.
Old 12-05-2016, 09:08 PM   #175
Dave, Give me a call and I tell you what I think is going on here.
Old 12-10-2016, 10:24 PM   #176
Dave Muller
This is a .120" thickness gasket that I tried out today. It does a world of good for my alignment issues! Unfortunately the port openings are rather large for a little 283.
Does anyone know a manufacturer (hopefully with part number) that makes gaskets .120" thick with port openings in the 1 7/8" to 2" range? I can use these if I have to, but I'd rather find something that is a little closer to the actual port size. So far my search has come up empty.
Old 12-10-2016, 10:32 PM   #177
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: '66 Malibu N/SA
see about a fel-pro 1245.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 12-10-2016, 11:24 PM   #178
Dave Muller
Oh, that looks great! Thanks.
Old 12-11-2016, 01:14 PM   #179
james schaechter
Cometic made me some thick intake gaskets for my 327 stocker that had a similar issue.
I never did any for my 283's but I am sure if you gave them specs and ordered a few they would do it
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 12-12-2016, 06:50 PM   #180
Dave Muller
This looks a lot better!
