Old 12-18-2016, 04:04 PM   #181
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Okay, the manifold is back on, and as a test I dropped in the distributor with no gasket. I measure an .026" gap between the bottom of the distributor and the manifold.
Here it is with an .030" shim and a gasket.
Hopefully it'll stay together a little longer this time.
Dave Muller is offline   Reply With Quote
Old 12-27-2016, 02:31 PM   #182
dmir55
If you don't think that gasket material will hold the distributor at the right clearance, I have seen valve spring shims used for clearance. Might have search to find one the right size but might give more peace of mind. Nice build.
dmir55 is offline   Reply With Quote
Old 12-28-2016, 03:36 PM   #183
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: '66 Malibu N/SA
Seems to me, the FelPro blue distributor base gasket seems to work as well as any for a combination gasket and spacer. The cheap gray fiber gaskets swell up and get soft after a while. Great build!! The valve spring shim is a brilliant idea. Just finding one the correct ID is the game.
Old 12-28-2016, 06:48 PM   #184
FED 387
Liked 335 Times in 182 Posts
If I remember we tried differential shims not sure what car but definitely was from a Chevy my partner at the time was a parts mgr so we used to shop the parts bins regularly might be worth a look otherwise depending on the ID of those spring shims they do work. FED 387
Old 12-29-2016, 01:59 AM   #185
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I'll measure one this weekend, but I'm thinking 12-bolt pinion shims might be a near perfect fit.
Rich Taylor
I/SA - 321
Old 12-29-2016, 09:53 AM   #186
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
If you find no other solution - http://www.streetsideauto.com/p/moro...FQ-QaQode-ICIw
Moroso 26150
Old 12-29-2016, 10:00 AM   #187
Alan Nyhus
Liked 800 Times in 237 Posts
Jegs, Summit, etc. offer these nylon dist. shims. -Al
http://www.jegs.com/i/JEGS-Performan...40082/10002/-1
"That'll never work....."
Old 12-29-2016, 01:18 PM   #188
FED 387
Now that I think more about it it was probably 12 bolt pinion shims you might get by with one or may have to stack them--- just remember consider tooth engagement between the cam and dist. gears--FED 387
Old 12-29-2016, 02:23 PM   #189
Dave Muller
Wow, that's a lot of ideas!
Actually, if you look back at my previous post you'll see I mentioned that I already have a shim (.030") in there, and yes it's one of these nylon shims. Seems like it should work fine.
Old 12-29-2016, 02:26 PM   #190
Jeff Stout
Liked 708 Times in 285 Posts
12 bolt shim is 1.45x 2.08 diameter if it helps anyone
