Old 01-09-2017, 01:21 AM   #1
Bill Baer
Default Separate back up button?
Does anyone use a separate back up button to put their PG solenoid in to engage reverse without engaging the delay box/throttle stop or starting line control cylinder?
I'm thinking I could wire one in the circuit with a diode preventing feedback to the delay box but I don't have any knowledge concerning diode sizing or ratings etc.
Can one of you Guys help me out with this?
Old 01-09-2017, 12:09 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Separate back up button?
You don't need a diode. The 12V when put to the transbrake is on the output terminal of the delay box and does not cause any issues in the delay box.
Dan
voltdr is offline   Reply With Quote
Old 01-09-2017, 05:03 PM   #3
63corvette
Liked 362 Times in 105 Posts
The Don Davis race car wiring diagram is setup that way for wiring the Davis cars.
I wired my own and did not use the separate button/switch because I thought it might accidently get tripped while moving to the staging lanes in low gear causing a real issue.
The wiring diagram showed a simple on/off switch and I have looked at a few Davis cars which had the switch mounted on the dash panel.
I just chose not to use one.
Just My 2 Cents
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
Old 01-09-2017, 05:26 PM   #4
voltdr
I've used them in the past. I just used a toggle switch mounted on the dash, that way there wasn't a chance of accidentally hitting it while driving around, and I didn't have to hold the button down while turning the wheel.
Dan
Old 01-09-2017, 05:58 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
One side of button to +12 volts, the other side of the button to the Transbrake terminal of the delay box. That's it; no problems.
S/ST 51
S/C 53
Old 01-09-2017, 06:32 PM   #6
Jeff Stout
Liked 708 Times in 285 Posts
Could you use a momentary switch. You would have to steer with 1 hand and hold switch to go in reverse. That way you will never forget to flip toggle switch.
Old 01-09-2017, 09:58 PM   #7
SGSST109E
Liked 126 Times in 61 Posts
I use a toggle switch on the steering, just parallel the transbrake button. I use a red aircraft cover which protects the switch from being accidently hit.
SGSST109E is offline   Reply With Quote
Old 01-10-2017, 02:00 PM   #8
Lenny5160
Lenny5160's Avatar
In my dragster, I use a small microswitch on the top framerail in the cockpit. I can only have one hand on the steering wheel, but turning the wheel doesn't affect my ability to hold onto the button.
S/ST 51
S/C 53
Old 01-10-2017, 04:40 PM   #9
voltdr
If you use a toggle switch, you won't forget that it's on. As soon as you put the trans in low gear, to move forward, the brake will be applied. Then you know you have to turn off the switch.
Dan
Old 01-10-2017, 09:16 PM   #10
Shake & Bake
Liked 37 Times in 33 Posts
My trans brake button I use to back-up is mounted on a bar overhead right next to my dome light.....It isn't hot all the time...I flip a switch to put power to it, back up and then turn the switch back off..
Shake & Bake is offline   Reply With Quote
