Old 02-04-2017, 07:46 PM   #11
J&S Racing
Liked 327 Times in 87 Posts
Default Re: 69 Camaro B/S
Back at it.... finished cleaning the fire wall and 1 coat of por down, waiting on the correct color for the door jams and upper cowl. I'll tone down the shine with a few coats of satin.
We planned on notching the cross member for oil pan removal. I really like how Tim had his done for the 67 so I had my guy copy it with added Jack point and tow hook.Came out great!!!! Hope to have it mounted later this week.
Old 02-04-2017, 10:13 PM   #12
bigsixman
Liked 2 Times in 2 Posts
Nice looking build on your B/S Camaro!
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
Old 02-13-2017, 08:56 PM   #13
J&S Racing
Subframe installed with Speed Tech solid bushings.
Started getting the front suspension together..... Afco solid bushings top and bottom, Global West offset cross shafts and Afco low friction ball joints should keep the front loose. Santhuff shocks and landrum springs to handle the wheel stands.
Old 02-14-2017, 01:13 AM   #14
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Very nice work!
D
Old 04-01-2017, 02:35 PM   #15
J&S Racing
It's been a long battle but the steering is finally coming together.
The first problem I had was with the tie rods.... I planned on using the Baer tracker kit but had a problem with the inner tie rods being to long. After a lot if back and forth I decided to build inners. I'm happy how they came out.
I also ran into a issue with the column being compressed leaving a 1/2" gap between the rag joint and flange. We couldn't figure out why since there was no evidence of a front end collision. I think this happened from the body bushings being so bad.
I put a strap around the flange and tried to pull it out with no luck. I was able to slide the column down and everything fits great with no bind.
Gonna tackle the headliner this weekend then she's ready for the chassis shop.
Old 04-03-2017, 11:35 AM   #16
Dave Gantz
Liked 251 Times in 125 Posts
I may be too late and I'm sure you know better than me, but do you want a headliner in the car while it's at the chassis shop?
Looking good, by the way.
Old 04-03-2017, 08:10 PM   #17
J&S Racing
Thanks!!!!!
Initial thinking was it would be easier to install without the cage. Since I'm doing it myself worse case it's $70 if it gets damaged....I really don't want to pull the rear glass and plan on running a 12 point so the extra bars will make the back tough. I'll cover it with cardboard and the guy doing the cage said he will use a welding blanket.
Old 04-03-2017, 08:21 PM   #18
David Lee
Liked 346 Times in 126 Posts
Did your POR on the firewall also or just the frame?
Old 04-03-2017, 09:28 PM   #19
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Are those heim style tie rod kits legal in stock now?
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 04-03-2017, 09:30 PM   #20
Dave Gantz
Thanks!!!!!
I thought about all of that, too. The one car I was involved with, my partner did the headliner after the roll bar. I have a car currently that I'd like to leave the headliner in for reasons you state. I'll be doing that rollbar, so I'll only have myself to blame if I burn it down!
