Old 02-24-2017, 09:19 PM   #71
Woodfin
Liked 288 Times in 109 Posts
Default Re: Team Woodfin's Bantam Roadster Build
Dolly gets a dress
Name:	Dolly paint 004.JPG
ID:	38363   Click image for larger version
Name:	Dolly paint 005.JPG
ID:	38364   Click image for larger version
Name:	Dolly paint 006.JPG
Name:	Dolly paint 009.JPG
Old 02-25-2017, 09:14 AM   #72
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Larry…Good Luck with the testing today. Dolly looks good with the new lipstick. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-25-2017, 09:24 AM   #73
Woodfin
Old 02-26-2017, 12:08 AM   #74
Woodfin
A few small gremlins only allowed one 300 foot pass but even with that I can tell the car is an excellent piece. It carried the front tires about 2" high well past the 60' clock. Straight, smooth, easy
We will correct the glitches and be back out soon. I expect the next outing will show some good numbers.
Old 02-27-2017, 08:58 AM   #75
Woodfin
under the tower at Texas Motorplex, ready for the maiden voyage
Old 02-27-2017, 09:50 AM   #76
Hacksaw
Liked 312 Times in 175 Posts
Sorry to hear you had a few bugs but overall it sounds like things went well. Congrats!
Old 04-24-2017, 08:33 AM   #77
Hacksaw
Been to the track lately? Any updates?
Old 05-07-2017, 03:38 PM   #78
jswoodfin
Hack,
We were out a few weeks ago testing. Our tune-up is getting closer and each tweak to the EFI system is making more power. As we added power, Dolly became a handful. She was launching to the left and skating down track. We loaded up after 4 runs and have made chassis adjustments in preparation for the next outing. We're scheduled to test again at the Texas Motorplex next weekend and will report back.
Jeff
jswoodfin is offline   Reply With Quote
Old 05-10-2017, 08:52 AM   #79
Hacksaw
Jeff: Some things to consider. Make sure rear is square to engine centerline. Check circumference of rears and make sure pressure is equal. If you have a double wheelie bar, make sure it's not steering the car on launch. Adjust the rebound on rear shocks softer. If they are stiff and you go through any bumps, it will pull the rearend up off the track surface and you start to spin the tires. Hope this helps.
Old 05-24-2017, 11:31 PM   #80
jswoodfin
The suspension adjustments made Dolly launch straight and stay planted to the track all the way down. The converter is too loose, so it has been sent off to be tightened.
Our next event is scheduled for June 10 and we are cautiously optimistic that the performance will significantly improve.
