#11 |
Liked 346 Times in 126 Posts
Anything to reduce cost and bring new blood into class racing, I welcome, what can i do to help this ball rolling forward
#12 |
Liked 66 Times in 37 Posts
The quota is full with 4 grade points. They want less stockers not more. Top dragster is much more fan appealing. Just watch the stands empty when they call Stock.
72 cutlass |
#13 |
Bless your heart.
Ed Wright 4156 SS/JA |
#14 |
Liked 238 Times in 111 Posts
Me, for 1
Dave Noll, EF/S ,?/SA 6526 |
#15 | |
Liked 5,114 Times in 1,948 Posts
The guys are still going to be members and comp numbers users, in most cases. That is, unless they don't care about memberships anymore either. Are they relishing in de-evolution then? Who knows? Maybe Devo was right. LOL
#16 |
Liked 1,954 Times in 491 Posts
Honestly, from the perspective of someone on the outside looking in, Most current racers in the bracket classes don't understand class racing AT ALL. I was surprised when I asked questions about S/SS how many racers couldn't tell me the first thing about them. Now the people that do run the class, well they aren't talking either because they aren't giving away any secrets. Case in point, I have a 2005 GTO I could run as an 04 and probably be moderately competitive, now there isn't many of these out there but first on the agenda would be a solid axle swap, when I contacted people involved with the current cars in the class I got vague answers and a "no pictures" reply. Now I get it for sure, but it sure makes me think a S/G car might be looking good at this point. Also... and this is a big one, completely take away the cost of the car and look at the cost to get there, race, then get home plus the time off work, let alone the countless hours to hone the combo, I can easily see how these classes would be unobtainable to most.
#17 |
#18 | |
Liked 2,336 Times in 549 Posts
#19 |
#20 |
Liked 747 Times in 362 Posts
This sounds like a great idea to me.
I've wondered why a lot of 2-barrel BOP engines are not raced. When I look up the specs, it appears that some of these 2-barrel engines are only rated maybe 40hp less than a very similar engine which can use an 800cfm Q-jet. So, that brings up a question which should be in line with this thread. For most GM carb engines, 350 cubes & bigger, aprox how much less power is possible when only a 2-barrel is allowed ? It appears to me that a 2-barrel would be the limiting factor, whereas an 800 Q-jet would not pose a limit at all, since there are lots of 9 & 10 sec cars, using 750 & 800 Q-jets. So, considering this, what would be a good number to begin with, for most GM BOP 2-bl engines, that are not being raced ? Or, to put it another way, how much less should the initial factor be, as compared to a very similar 4-barrel engine ? Since I'm a Pontiac guy, I'll just use a '76 Pontiac 350 as an example. I just looked it up on the Class Racer Info site. The 2-barrel version is factored at 220hp. The 4-barrel version is factored at 260hp. I've seen the 4-bl version in a competitive car. Have never seen the 2-bl version. So, aprox how low would the factor have to be, to make the 2-bl version competitive, or at least run a safe amount under the index ? I'm assuming a properly built & tuned car. http://www.classracerinfo.com/Engine...3&MAKE=Pontiac http://www.classracerinfo.com/Engine...4&MAKE=Pontiac If this post is out of order for this thread, please delete it. Thanks ! Last edited by oldskool; 03-06-2017 at 06:02 PM. |
