Old 03-14-2017, 01:04 PM   #131
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default Re: 79 Mustang project U/SA
Originally Posted by RobbieRacer View Post
Im making it look like a 79 Cobra. I like the 2 tone paint. It looks much better in the pictures. I'm hoping sanding and buffing helps. Not to bad for my 1st time painting..
Turning out good
Mitch Beri- The Motor City
Old 03-14-2017, 01:06 PM   #132
black88coupe
Originally Posted by Dave Muller View Post
I'm betting sanding and buffing will make a world of difference!
X2! Will definitely make a difference.
Old 03-14-2017, 07:18 PM   #133
S/ST J718
Robbie, Looking real good, paint looks good so that shows you did a great job with the prep work. Thanks for the update , hope to see you running the new Arizona Stock / Super Stock Assoc. events....
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
Old 03-15-2017, 10:38 AM   #134
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
As soon as the car is running I will be there.
U/SA
79 Mustang
Old 04-21-2017, 11:00 AM   #135
RobbieRacer
I thought I would go ahead and post an update.It's been a while. I have made a little headway. I got the dash repaired, painted and installed. I mounted the seats on the factory seat rails. They were too wide at 14 inches but I swapped them from inside to outside and they are only 9 inches wide. I mounted the seats on plate steel then mounted them to the rails. It came out real good. Nice and solid.Also got the brakes done. Nothing fancy but they work. I might up grade them later.
ID:	39007   Click image for larger version
U/SA
79 Mustang
Old 04-21-2017, 11:23 AM   #136
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
I'm glad to see that there's been some progress.
Dave Muller is offline   Reply With Quote
Old 04-21-2017, 12:24 PM   #137
black88coupe
Cool. Good update.
Old 04-22-2017, 10:18 PM   #138
john lemoine
Liked 7 Times in 5 Posts
what are you using to replace the rubber bushings in upper and lower control arms any part numbers available thanks
john lemoine is offline   Reply With Quote
Old 04-29-2017, 09:53 PM   #139
RobbieRacer
I put in poly bushings. I dont remember the numbers but I found them online.
U/SA
79 Mustang
Old 04-29-2017, 10:00 PM   #140
RobbieRacer
Well today was a good day and a bad day. I had a new windshield installed. But when I put the front rims on I found that they don't clear the SN95 front break calipers. I like my old school rims but I guess ill sell them and get different ones.
U/SA
79 Mustang
