Old 05-02-2017, 09:44 PM   #91
Default Re: My 88 Olds wagone U/SA 10 Pennies
All the new NHRA phony baloney valve job all done, already?
Old 05-02-2017, 10:30 PM   #92
SSDiv6
Liked 1,603 Times in 583 Posts
Old 05-03-2017, 12:47 AM   #93
Jeff Stout
Liked 706 Times in 283 Posts
I went with the .005 per 1 CC and what I ended up with after being to small was .003 per 1 CC. I mistakenly just went for it and didn't check between cuts and ended up 6 cc's to small. So instead of cutting valves seats deeper and try and get back the 6 cc's ( which I doubt I could)I just bought a head. The second head was brought down the right amount and checked during cutting and the .003 per 1 cc worked on this head. Tomorrow the third head will be checked and should be ok. With this being my first time building instead of paying I learned a great lesson.
Old 05-03-2017, 01:01 AM   #94
Jeff Stout
After sitting home tonight thinking about it I'm guessing if I had 2 different thickness head gaskets and the same bore I could have determined how much the 2 were in cc's and used that for a better gauge. Yes No maybe?
Old 05-03-2017, 07:30 AM   #95
HP HUNTER
Liked 373 Times in 129 Posts
LOL awwwwww
Old 05-03-2017, 07:32 AM   #96
HP HUNTER
But what about your piston to valve..................
Old 05-03-2017, 09:30 AM   #97
Jeff Stout
Cam has not been made and shipped yet. Ive heard from 2 others that valves wont need to be sunk to make piston to valve fit.
Old 05-03-2017, 12:29 PM   #98
SSDiv6
Correct, the Oldsmobile cylinder head is an inline design with a 6 degree valve angle. Completely different to a Chevy head with a 23 degree valve angle.
Old 05-04-2017, 11:38 PM   #99
2021STK
Liked 17 Times in 14 Posts
Sounds like it will be the "Wheeler dealer Wagon" Good Luck, I'll keep following your progress.
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 05-05-2017, 09:26 AM   #100
Jeff Stout
Great name for this project as I have been trading, ebaying, swap meeting parts for this project. Just bought complete new front steering components and a-arm bushings as the originals are shot $111.00. The third head was warped .020 and was not worth cutting as I was sure it would be to small after CC'ing. Fourth head was only .004 warped and after clean up it cc'd correct. Total $3666.50
