Old 05-19-2017, 10:40 AM   #111
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Did they deck the block ? If not that could be the reason.
U/SA
79 Mustang
Old 05-19-2017, 12:37 PM   #112
SSDiv6
Originally Posted by Jeff Stout View Post
Also I was surprised when removing torque plate cylinders were. 0015 out of round up top. Bolted plate down again and checking cylinders were round again. It surprised me.
Normal for the the Oldsmobile 307 and 403 blocks.
They are of a lightweight design, light and have scalloped and windowed mains. For a full race engine, you can fill the block and used a girdle, or sleeve to a 307 bore size, a 1968 thru 1971 high nickel block.
Old 05-19-2017, 12:45 PM   #113
Jeff Stout
Liked 706 Times in 283 Posts
Yes block was filled to bottom of water pump holes. Didn't know we could run a stud girdle. Ill look into that. Block was decked. We actually had to cut .034 to get zero deck. I have a 71 350 block but being a budget build I didn't want the expense of sleeving down to 307 bore
Old 05-25-2017, 02:36 PM   #114
Jeff Stout
Slow progress but progress. Cleaned up oil passage on main cap. Removed burr on hole entrance and the port to block had a large restriction dog leg in it. So I straightened dog leg in port. The oil hole in block was about .060 smaller then oil hole in cap so I matched those. Drilled and tapped passeges in main caps to run oil restrictors.
Old 06-10-2017, 03:12 PM   #115
Jeff Stout
Little update. Went on Ebay shopping spree. Clevite bearings, rear seal to replace rope seal , and HV oil pump $149.48 Total $5530.98 No pics as Im waiting on rings to complete short block. Then front end rebuild and valvetrain purchase.
Old 06-13-2017, 10:19 PM   #116
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Kinda thought that is the reason for honing with a torque plate, to make sure the cylinder is round when the head is bolted on.
Mike Moller
NHRA 203 Q-R-T/SA
Old 07-29-2017, 01:41 PM   #117
Jeff Stout
Some updates. Purchased beehive springs with retainers and keepers $291. Heads are 1cc over minimum, runner were 3-5 cc's less then maximum. Basic 3 angle valve job. The compression thickness total will be .004 more then allowed. Motor is no even close to being illegal.
New total $5821.98
Old 07-29-2017, 01:48 PM   #118
Jeff Stout
I was concerned with stock 12 bolt yoke and purchased a Strange yoke and u-bolts along with 1 Carrier main cap and reinforced rear end cover $377
New Total of $6198.98
Old 07-29-2017, 08:11 PM   #119
J.R. Haddad
Liked 1,471 Times in 308 Posts
Jeff, your previous total was 5500.00 and change. New total 4400.00
and change. This is the same accounting I use when explaining
Race Car expense to my wife. J.R.
J.R. Haddad is offline   Reply With Quote
Old 07-29-2017, 09:42 PM   #120
Jeff Stout
LOL. My significant other doesn't even know about the first dollar spent on this project. I type this stuff when I'm by myself. Thanks for catching it. Now updated. Also I need to get my pics on Flickr or if someone has a better place to host pictures.
