Old 08-14-2017, 11:59 PM   #1
suprgasn
suprgasn's Avatar
Default Trans brake push buttons
Who has the quickest releasing push button. Need to do something different. What's out there and working for you. Thanks
suprgasn is offline   Reply With Quote
Old 08-16-2017, 07:34 PM   #2
Chuck Westcott
Chuck Westcott's Avatar
Default Re: Trans brake push buttons
Well ? There a few that are relatively Quick. Look for one that has a (Micro Switch) like the Biondo .00 Button- Very Quick--- Dedenbear has a similar Button.
I've also used a Button switch made my Carling # 2x894- Extremely Quick but the Spring weakens with Heat as they all do- need to replace 2 times a year /
Good Luck
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 08-19-2017, 01:54 PM   #3
SST3193
Liked 2 Times in 2 Posts
Always used Honeywell micro switches. They make one that's button is about .09" diameter and only has about .03" travel. Friend put one in his SS car and it's lightning for him.
SST3193 is offline   Reply With Quote
Old 08-24-2017, 12:11 PM   #4
Mike Gray
Mike Gray's Avatar
Liked 703 Times in 203 Posts
You don't need those expensive name brand switches.
I found a bunch of surplus micro switches at a local electronics store (Orvac) that were $1.50 a piece. This is the quickest of the bunch, almost too quick and a little hard to feel with gloves. They had a bunch of different buttons and I picked one that suited me the best.
Name:	Micro switch1.jpg
