Old 08-28-2017, 03:14 PM   #131
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Bob Mulry View Post
That was the old rules......................
Now you can run a solid flat tappet lifter or a solid roller lifter as a replacement for the hydraulic lifter....
If it was hydraulic flat tappet is can be switched to a solid flat tappet and if it is a hydraulic roller lifter it can now be switched to a solid roller lifter...
Just trying to help with your budget.....
Bob
My problem is finding a solid roller in a.920 diameter. I wish that rule was changed to any diameter
Old 08-28-2017, 06:37 PM   #132
HP HUNTER
Liked 373 Times in 129 Posts
Jeff
You make the hyd roller lifter and solid roller lifter, moly tube stock and a lathe.
Old 08-28-2017, 06:54 PM   #133
Jeff, I just figured out how much I needed for shims on the Monte lifters, then went over to Mark's Bolts and Nuts with my calipers, and got a big batch.. by the pound !.
Left about .010 -.015 of travel and zero lashed it.
Goes along with your budget.
Old 08-28-2017, 07:55 PM   #134
SSDiv6
Liked 1,599 Times in 583 Posts
Mark,
Like I shared with Jeff, be careful with the washers.
Commercial washers, even the high strength ones, are usually Chinesium and will deform.
Talking from actual experience with some lifters I shimmed with high grade hardened washers and they squeezed to a thinner dimension.
Ended buying some 7075-T6 Aluminum round stock and cut it to the proper length.
Old 08-29-2017, 10:33 AM   #135
Alan Nyhus
Liked 799 Times in 236 Posts
I use stainless steel machine shims to shim lifters. They are available in many O.D./I.D. sizes and thickness. -Al
"That'll never work....."
Old 08-29-2017, 01:07 PM   #136
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Since I am not an Old's guy, just an old guy, I'm not sure that I understand???
I think that you run an .842 diameter roller lifter, but I am not sure????
What dimension is the .920 diameter that you are referencing ????
Just gathering info..
Thanx,
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-29-2017, 02:28 PM   #137
Jeff Stout
Hi,
Thanx,
Bob
Im not a Olds guy either or even a engine building but the opportunity came about and I decided to try it and if i doesnt work then Im not out a ton of cash, anyway Olds hydraulic roller lifter is .920 diameter. Seeing how I cant bush down to .842 im stuck with converting to solid.
Old 08-29-2017, 02:36 PM   #138
Jeff Stout
test
Im finally smart enough to post a picture and not shortcut. Only 30 minutes to figure out. IRSMART
Old 08-29-2017, 02:47 PM   #139
Bob Mulry
Bob Mulry's Avatar
I didn't see a spec for lifter diameter in the NHRA Technical Bulletin for a 1988 Oldsmobile with a 307ci engine, but classracerinfo.com said .842 lifter?????
On line it looks like only the early Oldsmobile's take the .921 lifters????
Have you measured the lifter bores in your 307 block????
I am just confused
Bob Mulry 7516 STK
A & M Motorsports
Old 08-29-2017, 03:23 PM   #140
Jeff Stout
I am just confused
I'm not at shop now but bores measure 920. I'll have to look at specs. Your making me second guess now.
