#131 | |
Liked 706 Times in 283 Posts
#132 |
Liked 373 Times in 129 Posts
#133 |
Liked 5,135 Times in 1,958 Posts
Jeff, I just figured out how much I needed for shims on the Monte lifters, then went over to Mark's Bolts and Nuts with my calipers, and got a big batch.. by the pound !.
Left about .010 -.015 of travel and zero lashed it. Goes along with your budget.
#134 |
Mark,
Like I shared with Jeff, be careful with the washers. Commercial washers, even the high strength ones, are usually Chinesium and will deform. Talking from actual experience with some lifters I shimmed with high grade hardened washers and they squeezed to a thinner dimension. Ended buying some 7075-T6 Aluminum round stock and cut it to the proper length. |
#135 |
Liked 799 Times in 236 Posts
I use stainless steel machine shims to shim lifters. They are available in many O.D./I.D. sizes and thickness. -Al
"That'll never work....." |
#136 | |
Liked 320 Times in 102 Posts
Hi, Since I am not an Old's guy, just an old guy, I'm not sure that I understand??? I think that you run an .842 diameter roller lifter, but I am not sure???? What dimension is the .920 diameter that you are referencing ???? Just gathering info.. Thanx, Bob
#137 |
Im not a Olds guy either or even a engine building but the opportunity came about and I decided to try it and if i doesnt work then Im not out a ton of cash, anyway Olds hydraulic roller lifter is .920 diameter. Seeing how I cant bush down to .842 im stuck with converting to solid.
#138 |
test
![]() Last edited by Jeff Stout; 08-29-2017 at 02:39 PM. Reason: more |
#139 | |
I didn't see a spec for lifter diameter in the NHRA Technical Bulletin for a 1988 Oldsmobile with a 307ci engine, but classracerinfo.com said .842 lifter????? On line it looks like only the early Oldsmobile's take the .921 lifters???? Have you measured the lifter bores in your 307 block???? I am just confused
#140 | |
