Old 08-29-2017, 03:24 PM   #141
SSDiv6
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Bob Mulry View Post
I didn't see a spec for lifter diameter in the NHRA Technical Bulletin for a 1988 Oldsmobile with a 307ci engine, but classracerinfo.com said .842 lifter?????
On line it looks like only the early Oldsmobile's take the .921 lifters????
Have you measured the lifter bores in your 307 block????
I am just confused
Bob,
1966-1967 400 and 425 Olds engines use a .921 Dia conventional hydraulic lifter.
However, the 1985-1988 Olds 307 with peanut ports, rated at 138 HP, and the 1981-1985 Olds 350DX diesel engine use a .921 hydraulic roller lifter.
Old 08-29-2017, 04:06 PM   #142
Liked 5,139 Times in 1,962 Posts
Mark,
Like I shared with Jeff, be careful with the washers.
Commercial washers, even the high strength ones, are usually Chinesium and will deform.
Talking from actual experience with some lifters I shimmed with high grade hardened washers and they squeezed to a thinner dimension.
Ended buying some 7075-T6 Aluminum round stock and cut it to the proper length.
I will plead guilty of not using much RPM and valve spring pressure on our latest combo.
So, when in doubt, leave it to the engineer.
Old 08-29-2017, 07:15 PM   #143
SSDiv6
Talking Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by mark yacavone View Post
i will plead guilty of not using much rpm and valve spring pressure on our latest combo.
lol!
Old 09-03-2017, 04:59 PM   #144
Jeff Stout
Liked 706 Times in 283 Posts
Here is rear end set up I hope for the last time. I think pattern is good as it took around 6 adjustments to get this pattern. Scored a set of used complete wild wood brakes. $215 shipped. The rotors were shot but I have a new set in the drawer that are drilled and were spares from old car I sold. Also the caliper mounts have a large hole for big Ford bearing that I will need to address. Total $6862.98
Old 09-04-2017, 01:25 PM   #145
Bunkster
Liked 43 Times in 10 Posts
Ratio?
Bunkster is offline   Reply With Quote
Old 09-04-2017, 06:48 PM   #146
Jeff Stout
Originally Posted by Bunkster View Post
Ratio?
6.14. with biggest 30x9 I could find. I've been told I should go the other way. 5 something ratio with a 27,28 tall tire but this is what I found for now
Old 09-05-2017, 09:19 AM   #147
GTOMayhem
Liked 22 Times in 14 Posts
OK, stupid question time. What are the advantages/disadvantages to larger vs smaller tires with corresponding ratio changes? Is it because of the low HP engine? Big car?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 09-05-2017, 09:55 AM   #148
Jeff Stout
Rick Thomason
GTOMayhem
Some have been saying that I don't need to drag a big tire all the way done the track when I'm a low HP car.
Old 09-05-2017, 11:29 AM   #149
nickh
nickh's Avatar
Liked 667 Times in 201 Posts
Jeff are you looking at the lightweight radial or is that bad for such a heavy car?
Old 09-05-2017, 11:29 AM   #150
Jerry Terry
Jerry Terry's Avatar
Liked 450 Times in 133 Posts
They are probably right Jeff, when i raced the1968 BelAir wagon it was hard pulling those tires but actually we started airing them up a little at a time and we would go faster and it still hooked okay it also depended on the track but it hooked almost everywhere.
Jerry
