Old 09-25-2017, 03:06 PM   #31
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: H-I-J '76 Nova re-fit.
Where you located at? I know you ran at Bradenton, I race at Gainesville. Car looks cool.
Robert
Robert Simpson is offline   Reply With Quote
Old 09-25-2017, 03:23 PM   #32
Nmbr1GMfan
Robert
I live in Sarasota, My daughter is taking the S/G Frank Hawley class in Gainesville Dec. 27-28 and we will stay the weekend to race the New Years race even if its only in the Jr.
Also anyone on FB can send me a request Todd Greene in Sarasota, FL.
Todd Greene
Old 09-25-2017, 07:43 PM   #33
Nmbr1GMfan
Well, on the one pass there was a definite driveline vibration before the 660. I found that the u-joint had some play in the pinion yoke (stock yoke) so I ordered a new yoke so now the driveshaft has small joint caps and the yoke has a 1350 joint, I was gonna have a new shaft made but now I'm thinking of using a conversion joint to save $400.
Todd Greene
Old 09-30-2017, 05:41 PM   #34
Nmbr1GMfan
New yoke installed, new u-joints and the driveshaft is in. Rear cover leaks real bad so I pulled it off to re-seal, possibly seeping out the two bottom bolt holes that are open from the old 12 bolt cover. Everything looks pretty good but nothing special in there, could probably use some good caps, bolts and a sturdy cover.
Todd Greene
Old 09-30-2017, 06:23 PM   #35
Todd, Those girdle covers really work. After a while you can see wear on the left cap from the load bolt.
Not much on the right.
I wouldn't run a stick car without one.
Old 10-01-2017, 08:22 AM   #36
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Those covers also serve to keep the housing from flexing. That big open hole in the back removes a lot of material that allows the casting to bend. Step up to 3/8" bolts there and use a steel cap on the left side with 1/2" bolts and you will also see longer pinion life.
Dwight Southerland is online now   Reply With Quote
Old 10-01-2017, 11:30 AM   #37
Nmbr1GMfan
Thanks guys, I'll swap the caps out and put good fasteners in it for sure. I need to see if I can get the 12 bolt cover bolts that have been ground off out of the housing where they installed the 10 bolt cover so I can get the good girdle cover on it.
Todd Greene
Old 10-01-2017, 01:08 PM   #38
Alan Nyhus
Liked 800 Times in 237 Posts
I saw that........
"That'll never work....."
Old 10-01-2017, 02:47 PM   #39
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Left-hand drill bit should spin them out easily.
Rich Taylor
I/SA - 321
Old 10-01-2017, 02:51 PM   #40
Nmbr1GMfan
I hope so.
Todd Greene
