Old 12-01-2017, 06:29 PM   #4971
marfen
Liked 16 Times in 9 Posts
I just consigned it to BJ in Palm Beach for April. I need the location of the blue box system. I have the wiring diagram and see a few blank holes in firewall/inner fenders etc. I have the original kit just need help installing correctly if anyone can help. Who knows, this stuff may have been first to throw in trash back then. VALDEZ
Maybe the holes are still there, mine were. it they were filled you probably should be able to see where they were from inside.
marfen is offline   Reply With Quote
Old 12-01-2017, 06:31 PM   #4972
marfen
Heres a good shot of that hard to find little piece that is called the heater delete fresh air vent or box
liteweight
Did you or Don open it up when you were cruising to the ponderosa?
Old 12-01-2017, 06:36 PM   #4973
marfen
re cooling one of these huge hemis...one of my local speedshop owners/racer has been talking about this race coolant that has a much higher boiling point so if your motor gets hot it won't produce those lethal steam pockets near as soon. just in case you get hot.
Old 12-01-2017, 06:38 PM   #4974
marfen
Liteweight, beauty wiring.
Old 12-01-2017, 07:39 PM   #4975
Spyphish
Liked 679 Times in 180 Posts
Liteweight, if not too much trouble, I would love a copy of the blue box article. 1046 Hollis Road, Westlake, La. 70669. I owe you LOL Phish
Old 12-02-2017, 04:24 AM   #4976
LO23
Liked 5 Times in 5 Posts
Clint
I tried using the original 033 rad, but it would not cooI. I then changed the top tank so the outlet of the rad was on the passenger side to promote flow across the entire core. Helped but still heated.
The end result is the biggest rad Be Cool makes to fit in a Big Block A Body without any cutting and 2 puller electric fans. The tanks have notches and fit above the frame rails. After all this, I still have to watch the gauge on hot days. But then again, I do street drive mine every chance I get. Even on those hot days
liteweight
g]
Thank you for that info! I will monitor things closely, and if it looks like I need to, I won’t hesitate to upgrade. We did have the radiator freshly rebuilt; one more thing I was hoping to keep looking original, but not at the expense of my new engine!
LO23 is offline   Reply With Quote
Old 12-02-2017, 04:27 AM   #4977
LO23
Thank you, I will check into that also.
Old 12-02-2017, 11:00 AM   #4978
Liteweight
Liteweight's Avatar
Liked 31 Times in 19 Posts
Not a problem. PM me your email address. I will scan and send to you
liteweight
Old 12-02-2017, 11:04 AM   #4979
Liteweight
Liteweight's Avatar
Daryl,
I am thinking I read somewhere back a couple hundred posts that these were also thought to be installed on the Mexico export Darts.
Maybe someone has a "south of the border salvage" connection?
Absolutely Charlie. Not exclusive to LO BO cars. They came with all heater delete A bodys
liteweight
Old 12-02-2017, 11:07 AM   #4980
Liteweight
Liteweight's Avatar
Miy side was for sure. I think I told Don to open his.
It pretty much stays open all summer. All that excessive Hemi heat that waafts into the interior...
liteweight
