Old 12-11-2017, 11:12 AM   #151
Hacksaw
Liked 312 Times in 175 Posts
Default Re: H-I-J '76 Nova re-fit.
Like the results and impressed with your progress. Question, because your in the biz. What's the procedure for removal and touch up on a steel panel if welding is required after p coat?
Old 12-11-2017, 01:25 PM   #152
Nmbr1GMfan
The only real option is to get the color matched at a paint store and touch it up. I had a roll bar built once and coated it mostly together then welded it in, I touched it up at a couple welds and it looked good. Powder can also be sanded and buffed after touch up, just be careful you don't use a heavy grit paper, start with 1000 and finish with 1500-2000 and buff with a wool pad.
Todd Greene
Old 12-11-2017, 01:36 PM   #153
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
The only tool I trust when working with springs Todd... https://www.otctools.com/products/fr...ing-compressor
Rich Taylor
I/SA - 321
Old 12-12-2017, 09:59 AM   #154
Alan Nyhus
Liked 799 Times in 236 Posts
Todd, G.M. used to have one available that used a plate like the OTC on the bottom and the threaded rod came up through the shock mount hole in the upper control arm. I believe Kent-Moore made them for G.M.
"That'll never work....."
Old 12-12-2017, 11:08 AM   #155
Nmbr1GMfan
Yes one that would run through the shock hole would be the hot ticket, the plate ones are far better than the one I have.
Todd Greene
Old 12-13-2017, 03:08 PM   #156
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I have a compressor for well over 40 years.
J hook style with a center bolt. One short and one long hook on each end.
Slips in thru the shock hole and just spin it apart to get it in or out.
You can pull a spring down straight or curved by moving the hooks.
GM cars were often curved in the front nd makes it real easy.
Just position the spring right during install to get it to seat properly top and bottom...
It has never failed me.
I even did springs without a compressor using the lift and a jackstand......got a little iffy at times...
Rich Biebel
S/C 1479
Stock 147R
Old 12-15-2017, 09:19 AM   #157
Nmbr1GMfan
Did just a little yesterday, started cleaning brake parts and got the steering parts prepped and painted.
Todd Greene
Old 12-16-2017, 10:24 AM   #158
Nmbr1GMfan
Powdercoat cleared the rear cover yesterday, I think I liked it better raw but they just don't clean up so this will make it easy. Picking up some parts now then gonna get a few things done today.
Todd Greene
Old 12-16-2017, 07:07 PM   #159
Nmbr1GMfan
Front end is buttoned up, shocks are in, steering is all back in. I put the rear backing plates in backwards so the e-brake cable holes were backwards so fixed that and installed the rear cover and shocks. Quickly threw the pedals, dash, a seat and doors in so we can get the cage in next week. Doing some family stuff tomorrow and putting some lights on the house so no car time tomorrow.
Todd Greene
Old 12-18-2017, 01:29 PM   #160
Nmbr1GMfan
Dropped off to get the cage in this morning, should have it back end of the week.
Todd Greene
