Old 02-04-2018, 11:02 PM   #1
Rory Christianson
Liked 9 Times in 6 Posts
Default Super gas hood rule
Hi
Just working on a super gas car which is getting a enderle stack injection so stacks will be sticking through the hood.
Car will have a hood just no scoop over the stacks is that fine in super gas ?
Or is there a rule stating otherwise ?
Thanks
Rory Christianson is offline   Reply With Quote
Old 02-05-2018, 01:50 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Super gas hood rule
Check with a tech. There is a reference to an 11 inch rule for hood scoops on SS and SG, but no stated exemption for stack injecters. If a carb has to be covered then injectors might also.
Dale Shearon
68 Mustang 6394
Old 02-05-2018, 09:50 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Only carbs sticking thru the hood need a flash shield to prevent fuel from siphoning out .
Stack fuel injection is ok without a scoop or flash shield ,as there is no fuel bowl or vent for fuel to siphon out of .
I would defiantly run screens in the stacks . hard enough to keep debris out of a carb let alone 8 stacks !
Old 02-05-2018, 11:29 AM   #4
Keith 944
Keith 944's Avatar
There is a 55 Chevy that runs stacks in s/g saw him at Maple grove I believe. X2 with the screen!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-05-2018, 10:56 PM   #5
Rory Christianson
Thanks guys appreciate the info
Yes I was going to run some kind of screens
Any thoughts of pros and cons to making one competitive ?
Thanks again
Old 02-06-2018, 12:28 AM   #6
Tom Goldman
Thanks again
the down side of mechanical injection is that for it to make it work consistently on a throttle stop usually requires closing down to Idle.
Some racers have had some success using a part throttle bypass off the barrel valve [similar to what a Sprint car or old Modified Stock car would have used ]. by using a controlled bypass on the barrel valve I've known a few racers who successfully got the injection to cruise on the stop at around 4000 rpm. But most guys opt for going to idle as it yields much higher MPH .
Kinsler used to offer a nice slip in domed screen that had a formed ring that secured in the stack tube. ...not sure if they still have them.
Old 02-06-2018, 09:35 AM   #7
Rory Christianson
Thanks
I will look into both and see what I can figure out with it.
Wanted to run it for the nostalgia look which I like, but if it had to many disadvantages in a .90 class car I didn't want to be fighting myself against consistency either.
Thanks again
Old 02-06-2018, 11:50 AM   #8
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Thanks
Thanks again
If you have it, try it. Launch and go back to idle as quickly as possible. Only have enough time WOT to get a good reaction time.
My S/C car has Ron's Terminator mechanical injection, and I think it repeats very well.
S/ST 51
S/C 53
