Old 02-20-2018, 10:39 AM   #1
ac302
Default Mph
Running super street. Will I gain any mph going from a 4.86 rear gear to 4.30? 950 hp car trapping about 140-142ish
ac302 is offline   Reply With Quote
Old 02-20-2018, 12:13 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Mph
Difficult to say. I would doubt it, as the car will have a more difficult time getting up to speed when it comes off the stop.
S/ST 51
S/C 53
Old 02-20-2018, 01:25 PM   #3
voltdr
Liked 100 Times in 51 Posts
Default Re: Mph
I agree with Lenny5160. Converter lockup will change dramatically, It will slip more. Maybe try the 4.56 gear.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 02-20-2018, 01:35 PM   #4
ac302
Default Re: Mph
My thoughts too. Was getting suggestions from others that I would pick up alot but I'm not sold on it
Old 02-20-2018, 02:15 PM   #5
Keith 944
Keith 944's Avatar
Default Re: Mph
Rpm=mph
That’s the short version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-20-2018, 02:36 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
Default Re: Mph
Hear lots of good things about the APD Max Speed....seems like better way to go if you don't mind changing to a different setup. There's another thread on throttle stops which got me doing some research.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-21-2018, 10:45 AM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Mph
That is a 12% change in gear ratio . not taking into account the probable loss of converter efficiency that will occur , that's a nearly 1000 rpm drop in trap rpm.
Not to mention the loss of reaction time and loss of acceleration coming off the stop.
I'd be talking to your converter guy , maybe looking at a lower stall higher efficiency converter using the existing gear.
You didn't mention what your trap RPM is . ....Is that a concern that it's too high ?
Old 02-28-2018, 04:10 PM   #8
DB
Default Re: Mph
Mine did.
DB is offline   Reply With Quote
Old 06-01-2018, 03:29 PM   #9
B1Ken
Default Re: Mph
I'm a little confused here. What does your car weigh? 950 HP and only 142 mph? Something doesn't calculate. I had a Super Street car that went 148-150 with 875 HP.
Car weighed 3000 lbs. (67 Cuda). I used 4.56 gears and hit the finish at about 7600 rpm. Engine made peak power at 7300.
B1Ken is offline   Reply With Quote
Old 06-09-2018, 11:15 PM   #10
gnicholson
Liked 4 Times in 3 Posts
Default Re: Mph
I have a 505 bbc in a 70 chevelle that made 860 on stinnets dyno a few tears ago and it only runs 137,139 best. 4.88 gear 14.5 32 tires. 3150 with me
gnicholson is offline   Reply With Quote
