Old 08-09-2016, 09:44 PM   #31
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Peanut Port Drag Test
Originally Posted by jcw31 View Post
It ran 10.80s at 7000 da is this corrected or what would you expect at 2000 da
I think that would depend on the barometer that the 2000 DA happened at.
Example: 2000 DA with a baro of 28.00
2000 DA with a baro of 29.40
Obviously the 2000 DA with the 29.40 baro WILL be faster than a 2000 DA with a 28.00 baro in my opinion. So to answer your question, I would say 10.40s in a 2000 DA.
Old 08-09-2016, 09:46 PM   #32
HP HUNTER
Originally Posted by Mike Taylor 3601 View Post
366 has same main journal size as other BBC don't know of many ever doing anything much with them,had a friend ran them years ago in Super stock 4wd pulling,they had 366'' limit,they made the rules don't guess they thought of anyone building 366'' BBC, he dominated it.
About all we have ever done besides build them back stock, is use the cranks,in 396,427's and use the rods for stock rebuilds.
366 wouldn't be good for any kind of budget build,by the time you had custom pistons made that would be more than the difference in $ of 454/427 block,could build bigger for same or less money.
HP,I like your build.
Mike Taylor 3601
Thanks for the nice comment!
Old 02-22-2018, 04:28 PM   #33
Jim Hanig
Liked 99 Times in 49 Posts
Originally Posted by HP HUNTER View Post
1.What drew you to this style head?
I was running out of 781 and 049 castings in my engine building buisiness.
2.Did you have to replace the exhaust seats?
No, on muscle car builds I do not replace seats, but I'am a fanatic on round strait properly sized and finished valve guides which lets me make a very concentric seat with a extremely nice contact patch that transfers heat good due to the valve setting down on the seat perfect every time. Tow applications get a 1.750 CHE exhaust seat.
3.How much do you think you increased the volume when finished?
I don't know I didn't check it, I machined, built, dyno tested, installed it in 7 days.
4. Did you have to fill the intake manifold to match, or was it close?
No, I smoothed the plenum divider, the intake is not the cork.
5. I have built tow engines close to this, this engine would be good in my dualie, except the 9.3 comp would worry me along with the 1.880 exhaust valve size. I will put a link up to my 489 tow build along with a picture.
http://speedtalk.com/forum/viewtopic...447590#p447590
6. Last is that Scott Welborns old car?
Yes, I bought it from Dale Hulquist the BSer, when it arrived I realized it would need a total rebuild from front to back, and thats what it got.
Why would you buy it ?
Old 02-23-2018, 12:00 AM   #34
HP HUNTER
After a front to back rebuild I've won several races with it, run incredibly fast with a production block/head combination, I love this car.......that's why
Name:	Vortecpro Chevelle.jpg
Old 02-23-2018, 10:20 AM   #35
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
👍 x2
Old 02-23-2018, 01:47 PM   #36
That answer deserves a bigger picture.
Old 02-23-2018, 09:15 PM   #37
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Nice lookin' and runnin' car.
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 02-26-2018, 12:27 AM   #38
Jim Hanig
👍 x2
It ran fast as stocker long before you rebuilt it.
Old 02-26-2018, 12:41 AM   #39
HP HUNTER
Thanks
Old 02-26-2018, 12:44 AM   #40
HP HUNTER
Did it run low 9s @ Kearney's 2130 feet elevation with 1.3 60s on the rear tires?
Name:	Vortecpro Chevelle rear view.jpg
