Old 04-02-2018, 02:06 PM   #1
Lyn Smith
Liked 994 Times in 200 Posts
Default Intake gaskets for 520 sbc heads
What Fel Pro gasket number works best for the 520 t SBC heads?I see some of their numbers look pretty big.Thanks .The Jr Stocker/Q/SA 265 is going together.
Old 04-02-2018, 03:18 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Intake gaskets for 520 sbc heads
100 was the old Mr Gasket number. Might be able to find a cross reference.
Ed Wright 4156 SS/JA
Old 04-02-2018, 07:12 PM   #3
FED 387
Liked 333 Times in 180 Posts
Fel Pro says their number 1256 is a mr gasket 100 crossover. 100 still available from Holley/ MrGasket
Old 04-02-2018, 10:23 PM   #4
Tom Meyer
Liked 354 Times in 120 Posts
1245 felpro is the thicker gasket, with the angle milling of the heads and intake they raise the intake up for a better shot at the intake valve ?? Had to do some trimming on my SS 520s. Tom
Tom Meyer 5240 SS Stock ???
Old 04-03-2018, 02:43 PM   #5
Ed Wright
Ed Wright's Avatar
The 100s were about a perfect fit on the stock 520s on my old Jr Stockers. I would expect some trimming on SS heads.
Old 04-05-2018, 12:04 PM   #6
james schaechter
Liked 1,438 Times in 301 Posts
The 100s will work. We had Cometic make some,small port thick ones for us a long time ago and they were perfect. I doubt if they have a part number for them. Might be able to look them up under our name. We haven’t run 283s in awhile, but I know Cometic will also make what you need if you send them the sizes or a trace of the intake
James Schaechter 3163 STK
Old 04-06-2018, 08:03 AM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
Fel Pro makes a 'trim to fit' intake gasket for SBCs:
#1244 are .060" thick, fits ports from 1.25" x 1.90" to 1.40 x 2.30''
#1245 are .120" thick (same ports sizes as above)
"That'll never work....."
Old 04-17-2018, 01:48 PM   #8
Lyn Smith
So I ordered some Fel pro 1245 because I liked the idea of them being thicker.That works ok,but the port mismatch is bad.The 55 intake is real small.Measures 1.55x.970.The head is 1.80 x1.20, and the 1245 gasket is 1.930 x1.24.Should I find some gaskets that are closer to the head size?
Old 04-17-2018, 09:34 PM   #9
MR DERBY CITY
Liked 8,047 Times in 1,528 Posts
100’s are the way to go....I assembled a few 283’s back in the stone ages......
