Liked 346 Times in 126 Posts
I just purchased on of these to go into my cuda and am looking for some mounting options. There is no center console in the car and would like to see what other people have done
Thanks Dave |
Liked 108 Times in 29 Posts
I bolted it directly to the tunnel with 1/4 inch bolts on our A body cars. My sons was little better fitting because of old floor shifter and the tunnel was flatter.
Larry |
Liked 24 Times in 13 Posts
^^^^^^^ Ditto ^^^^^^^^
Jeff Dudgeon '66 Coronet #10771 - bracket puke "the Flying Brick" |
Thanks. do you directly bolt it the floor boards and mount a little higher higher?This is for a 67 notch
Liked 10,681 Times in 2,222 Posts
Bolt it to the floor after you find out what is a comfortable location for you.
Liked 309 Times in 88 Posts
I usually space the front of the shifter up some as the neutral safety switch is tight against the floor in some applications.
On my son's 73 Dart we used washers under the back because of the angle of the cable going through the floor. Like others have said, what fits best for your comfort.
Liked 32 Times in 13 Posts
Mine is mounted on a pedestal on the tunnel bringing the shifter up an closer to me.
Liked 44 Times in 21 Posts
I use a piece of angle iron, so its sits up higher, and i weld the angle to the floor, with some flat bar on the other side for support, then bolt the shifter to angle.
Steven Barnes Stock 704 N/SA |
