#11 |
Vehicle weight is a big deal. Moser may offer a bolt-in 12 bolt. I would check with them.
Ed Wright 4156 SS/JA |
#12 |
Liked 53 Times in 16 Posts
Dan
Isn't that a 7.5 inch 10 bolt in the Impalas. ? I had to run Pro Gears in my 68 Impala, broke street gears, but then again a 4000 l b BBC stick car at that point. Running same 4:88's in my 65 automativ car. Will Lamprecht 65 Impala 396/325 |
#13 | |
Liked 184 Times in 113 Posts
B-body’s got the 8.5 inch rear. None of us in the Impala club are having problems. Unless they are using a Stick. Chipper brought up that the 8.5 rear uses the same bearings as a 12 Bolt. That makes it stout. Wonder if a 12 bolt ring and gear and Spool will fit in a 8.5 Pumpkin? |
#14 |
Still trying to figure out the best gear ratio.
Using 4.56s with a 4L60E trans. Not using the locking converter now. Looking at 5.38’s and locking it up in high gear. I can program that in the PCM... Hope to get close to the K/SA index with current cam. |
#15 | |
Liked 5,138 Times in 1,961 Posts
The Impala SS may have all come with the 8.5. Pinion bearings and flange are different, for one thing. 8.5 and 12 bolt take different side shims.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-21-2018 at 11:48 PM. |
#16 | |
All were 10 bolt 8.5 rear Camaro/FB all came with smaller 7.2 rear. They can surprisingly survive with a good bit of power too..! About a $1k less to beef up a 10 bolt than installing a prepared 12 bolt unit. They make them to fit our B-body. Interesting being the same suspension configurations as the early Chevelles, GTO, Cutlass, GTX. D |
#17 |
Liked 14 Times in 10 Posts
Generally the B bodies with the Baby LT-1 or 305 have the smaller rear. The LT-1's generally have the 8.5 (Impala and Caprice).
#18 |
Liked 239 Times in 114 Posts
The later F-Bodies got a beefed up 7.5 rearend , with a bigger 7 5/8" ring gear .
#19 | |
With the money you save from staying with the 10 bolt you can probably afford a golf cart and a tow strap. Eventually, you will need it.
James Schaechter 3163 STK |
#20 | |
Whatever you do , don't tell him the early Chevelles did not have the same suspension. Although it looks similar, it is not a metric configuration. Also , I have never seen a bolt in 12 bolt for those cars. Maybe those SS guys can help him. Apparently we are not qualified here.
