Old 04-22-2018, 09:09 PM   #31
MR DERBY CITY
Liked 8,131 Times in 1,535 Posts
Default Re: 12 Bolt vs 10 Bolt Rear
If Dan runs K SA and if I have figured his combo correctly at 299 HP the total weight including driver is 4055 lbs. I sure hope that 8.5 is as durable as a 12 bolt.
Old 04-22-2018, 09:56 PM   #32
Liked 5,138 Times in 1,961 Posts
You are right again....bluster blossom...
I am not under my car often...and that is a good thing!
and It helps to have a Forum to share experiences!
Mark you car is so slow.
It’s shadow waits for you at the end of the strip !
Dan
Wrong again . I don't own a race car.
Old 04-23-2018, 10:33 AM   #33
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Having withdrawal envy. 😀
Old 04-25-2018, 10:09 AM   #34
Dan Fahey
Dan Fahey's Avatar
Been talking with Moser, Mark Williams and Strange
They do not make a C Clip Eliminator Kit and Axles for a 10 Bolt and with Disk Brakes..
They do not have a 12 bolt that bolts in
Looks like everything has to be fabricated to make it work.
Anyone have an idea how to get past this??
One other questions.
Can you use a G-Body Rear on a B-Body?
D
Old 04-25-2018, 12:28 PM   #35
Race Clean
Liked 129 Times in 53 Posts
My experience is that weight is what kills a rearend.
I moved to a lighter class and the rearend problems stopped,I probably have 100 more hp today than I had when I was breaking gears but no sign of cracking nowadays.
Most abused 12 bolt I've seen is from a 283 Impala (stick)
Race Clean is offline   Reply With Quote
Old 04-25-2018, 02:40 PM   #36
reera
Liked 31 Times in 6 Posts
69 Nova 350/255/280. 3250# in G/SA. 3390# in H/SA. 8.5" 10-bolt rear. Broke a couple teeth off 1 set of gears in 7 years. Strange c-clip eliminators, 33 spline axles, spool, richmond gears. Your results may vary.
Ryan Walther
Stock 315
reera is offline   Reply With Quote
Old 04-25-2018, 03:48 PM   #37
Dan Fahey
Dan Fahey's Avatar
Ryan Walther
Stock 315
Oh have options.
But not one for my Axle using a Disk Brake.
Dan
Old 04-25-2018, 04:08 PM   #38
GUMP
Liked 2,361 Times in 558 Posts
You could always change the axle ends. It wouldn't hurt to weld the axle tubes to the center too.
GUMP is online now   Reply With Quote
Old 04-25-2018, 04:34 PM   #39
Dan Fahey
Dan Fahey's Avatar
Yeah..
Got a special case here.
Moser, Strange and MW do not specialize on B-Bodys.
Right now a new with good parts will cost $5000, Damn !
One asked if a G-Body 8.5 rear would fit.
Dan
Old 04-25-2018, 05:17 PM   #40
FED 387
Liked 333 Times in 180 Posts
look at the Police 91C rears they generally came with disc brakes---or as somebody said cut the ends off and put 12 bolt ends on it--google what you are trying to do others have put G body rears into a B body just have to rework the arms and move the brake hose/shock holes etc. to match what you have
