Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 04-29-2018, 10:19 PM   #1
oldsboy
Liked 8 Times in 3 Posts
Default Chevelle rear suspension
1971 chevelle need advice spinning rear tires current has drag bags 456 gear and 29-9-15
oldsboy is offline   Reply With Quote
Old 05-08-2018, 09:08 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Chevelle rear suspension
Probably would get more response on Stock /SS tech forum.
That said , this is one of the most worked out rear suspensions , lots of aftermarket parts available ,but can be made to hook like crazy with simple old school mods.
If you don't have them bolt on upper "no hop " brackets are the starting point .
they are necessary to get the 4 bar geometry to a usable intersection .
Stock arms can be boxed and reinforced and solid bushings installed ,but there are so many aftermarket parts available with bearings or bushings it not worthwhile using the stock stuff unless you're on a really tight budget .
Leave the rear anti roll bar on , disconnect or remove the front antiroll bar .
Good front arm bushings are a must ,but if you are on a budget you can grind the serrations off the inner sleeve and just snug the bolt , allowing more freedom of movement .
Good shocks are a must but , I've seen many an A body hook up great with just old school Chassis Engineering 3 way adjustable shocks.
As far as springs go , good stock rear springs will suffice , the front springs should be replaced with longer, lighter springs with more stored energy from Moroso or Landrum .
Use your air bags for preloading the right rear , good ballpark is 4-5 # left 10-15 #right ,if you need height,change the springs at use a cast aluminum spacer at the top.
You can probably do most of the work for under $500.
Old 05-08-2018, 09:28 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Some of what has been mentioned such as no-hops, but invest in a real anti-roll bar like a HRParts@Stuff and lose the airbags completely. The real trick is getting the front-end to work properly and no amount of tweaking on the other end will compensate for the other.
Rich Taylor
I/SA - 321
Old 06-17-2018, 10:16 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
Cheap Lakewood Bolt on traction bars work very well with single air bag on rt in spring.
Loose front shocks and check travel length. Very basic but helped my wagon
Old 06-27-2018, 04:40 PM   #5
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
you surely don't mean Lakewood bolt on ladder bars do you:?
had those POS's on a 66 Chevelle, bound up the rear end so bad, no amount of exlax could fix it....
Old 07-15-2018, 09:37 PM   #6
Dick Butler
These were an add-on type. did not replace any component. the 4 rear bars were the same just new rubber parts. Rear of bar bolts on frame and bumper hits under frame 32 inchs forward.
Old 01-24-2019, 03:45 PM   #7
will prater
Liked 7 Times in 4 Posts
Look at welding the tubes into the center housing. Depending on car weight and torque you can break the factory spot welds on a 12 bolt housing.
will prater is offline   Reply With Quote
Old 02-21-2019, 10:40 AM   #8
DG7050
Liked 115 Times in 31 Posts
If your in SoCal area talk to PMR racing. They have a chevelle stocker that works great. I crawled under the car and was amazed at what they were able to do with the factory set up.
DG7050 is offline   Reply With Quote
Old 06-15-2019, 08:08 AM   #9
ski_dwn_it
Liked 4 Times in 2 Posts
We spent many years racing a Chevelle and spent thousands of dollars. Only one system your will effectively work with these cars on small tires. You may have heard of the weibe suspension well ours built upon this system and improved some features.
Our 67 was 3850 and I'm 200 pounds. Car went 1.28 60ft with the rear wheels, 555ci 13.1 ALL motor engine. Stock 12 bolt with 3.73 gears on radial slicks. Car was like a zerox machine for 60ft times.
I build and sell these suspensions. Get in touch with me if interested. You will be much further ahead in the long run.
Here is our car.
https://photos.app.goo.gl/BNzy7MpMfawgBzZ96
ski_dwn_it is offline   Reply With Quote
Old 06-25-2019, 11:28 AM   #10
sean1970ss
Liked 10 Times in 6 Posts
Here is our car.
You have any photos of your system?
sean1970ss is offline   Reply With Quote
