Old 05-23-2018, 06:08 AM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default Car will not start.
The car started last week and went to start it this week and won't fire. We've changed everything. Any clue of what it might be would really help. Thanks.
TinSoldier 3215 is offline   Reply With Quote
Old 05-23-2018, 06:19 AM   #2
TinSoldier 3215
Default Re: Car will not start.
And no rpm on tac or big stuff if that helps.
Old 05-23-2018, 07:21 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 2,007 Times in 602 Posts
When mine wouldn't start it was the pick up on the crank trigger also one time my car would not start the needle and seat was stuck and no gas was getting in the carb. Had fuel pressure but no gas in the bowl. Check that
Mike Pearson 2485 SS
Old 05-23-2018, 07:23 AM   #4
TinSoldier 3215
Mike, we changed that. No luck
Old 05-23-2018, 07:26 AM   #5
Mark Howes
Liked 80 Times in 28 Posts
neutral safety wire ?
Mark Howes is online now   Reply With Quote
Old 05-23-2018, 07:35 AM   #6
Bobby DiDomenico
Liked 104 Times in 53 Posts
I'm with Mark. Thinkin something electrical. Did you check for spark?
Old 05-23-2018, 07:43 AM   #7
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Car will not start.
Check for spark & re-check all your Ground wires & connections !!!! Loose wires ?
Dave Ribeiro 1033 STK
Old 05-23-2018, 07:54 AM   #8
TinSoldier 3215
We've checked that to
Old 05-23-2018, 08:05 AM   #9
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
No rpm pulses when cranking suggests trigger pickup issues. 60-2 tooth wheel with Hall effect? They are very sensitive to gap. May have been right on the edge all along and now just out of range.
Old 05-23-2018, 08:44 AM   #10
TinSoldier 3215
Kevin. We have checked that 3 times. No luck
