Liked 31 Times in 10 Posts
Looking to replace the steering box on our superstocker and checking to see which one is recommended. Thanks for the help.
Michael Brand II 505B - F/SA |
Liked 99 Times in 60 Posts
M, you have several choices.
* S-10 manual box [with the S-10 box in most cases it is a direct replacement. Input spline & pitman spline same as OE. It will have a four bolt top] * manual GM box from 70's cars [this is also a direct fit in some cases. GM produced several spline counts so it takes some comparing to find the exact match. This is a three bolt top. This box is about one pound lighter than the S-10 box and overall slightly smaller. * Vega box [this box is smaller and lighter than both the above, however, it requires a custom/special pitman arm. Ed Quay, Flaming River, and maybe others furnish the special arm. Of the three, I would look for the 70's box.
Larry Woodfin 471W |
Liked 880 Times in 311 Posts
What about the ratio's?
Any difference in the ratios of the different boxes? Quicker or Slower?
Adger Smith (Former SS) |
Adger, I "think" all GM manual boxes will be about the same in ratio. [maybe an exception but it would be a rare option] The greater turn to turn ratio of manual boxes is an advantage, steering is not touchy]
The 60's and 70's three-bolt top gear is a good choice but it takes careful searching to find the correct spline count. They are out there, I have found and installed several. An S-10 box is available reman from most parts stores. To my knowledge, there is only one part number. It's advantage, a direct bolt in replacement, remove power gear, install S-10 manual gear. The quicker ratios come with PS boxes.
Liked 133 Times in 76 Posts
I used the S-10 box, direct bolt in. I could have answered the ratio question last week as I just sold a Vega with a stock box.
When I was building my Roadster I found a rack & pinion setup that had a lot higher ratio so it eliminated over steering it. Just wondered about the available Gen 3 boxes.
Thanks.
Liked 333 Times in 180 Posts
I have a Chevy book (from GM ) 1984 that lists 2 Manual steering gear assemblies
7806396-------20:1 ratio---- 67-75 Camaro 7819935-------16:1 ratio---- Monza and Vega FED 387 |
I did a little research on my Gen 3 tonight.
I found a 3 bolt top manual steering box It has a number on the top frame rail side that is 7808990 A quick search on the net seems to be the Vega box.
Liked 1,943 Times in 584 Posts
That's what my Buddies Gen 3 car has in it with an Ed Quay pitman arm. I have a Vega box in my gen 1 Camaro. It gives a bit more header clearance. They work fine and you can buy brand new ones from Jegs or Summit.
Mike Pearson 2485 SS |
