Old 05-28-2018, 04:10 PM   #1
prostockpete1
Liked 90 Times in 52 Posts
Default 1972 buick 350 real seal
what manufacturer offers a replacement 2 piece neoprene rear main seal to replace oem Rope for 1972 Buick 350 ?
prostockpete1 is offline   Reply With Quote
Old 05-28-2018, 04:28 PM   #2
Lyn Smith
Liked 1,000 Times in 202 Posts
Default Re: 1972 buick 350 real seal
TA Buick performance in AZ. has the 4 rear neoprene seals for a Buick 350 in their catalog for $16.95. I have a 72 350 4bl intake manifold if you are looking for one.
Old 05-29-2018, 07:36 AM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Use a ford 460rear main seal.
Old 05-29-2018, 10:27 AM   #4
prostockpete1
Thanks Glen .. to think that a Ford main cap has same dimensions as the Buick in seal area
Old 05-29-2018, 11:55 AM   #5
Chuck Norton
Liked 89 Times in 19 Posts
That's priceless!! An old-time rebuilder advised me that a rear main seal for a 312 Ford would work in an Oldsmobile 307 and that the rope seal could be avoided altogether. Didn't believe him until I tried it.
c
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 05-31-2018, 12:56 PM   #6
Tom Broome
Liked 88 Times in 43 Posts
I thought the 460 Ford worked in 455s, and the 350 took the same seal as the V6. Long ago I worked at Jim Ruggles' when we switched from rope to rubber. I thought the seal we used was from an AMC, but it's been a while.
I see that FelPro sells a neoprene seal for the V6s BS40613. Either way, make sure to polish the knurls down or it can chew the edge off of the neoprene seal (that much I do remember).
Tom Broome is offline   Reply With Quote
Old 05-31-2018, 01:21 PM   #7
Rory McNeil
Liked 1,112 Times in 304 Posts
c
Interesting, every Ford 312 I ever rebuilt used a rope rear main seal.
They did have a pressed in rubber seal in the front timing cover however.
NHRA 6390 STK
M/S 85 Mustang
Old 06-01-2018, 12:11 PM   #8
Glenn Briglio
231 has 2.500 main journal diameter. 460 ford and 350 buick both have 3.000 main journal diameter. Fel pro bs40032 is the one to use.
