Liked 232 Times in 39 Posts
On the racepak, how much delay from the RPM readout is the Air Fuel readout?
Marty Buth 3657 STK |
#2 | |
Liked 323 Times in 63 Posts
On my Holley system it seems to be .4 second.
Bob Shaw V/SA 515 |
Thanks Bob! I was expecting something like that How did you determine that amount of delay?
Liked 510 Times in 117 Posts
About .2 of a second on the racepak. I look at engine rpm and my shift point vs biggest fluctuation of O2.
68 Chevy11 327 F/S |
My delay is .2 second also. Each step on the graph is .5, not 1.0. I figured wrong.
Bob Shaw V/SA 515 |
Thanks Bob Gullett and Bob Shaw! Good information!
Marty, if your car is EFI, make a big change at like 6000 RPM, then see what RPM it shows up on your logger. I mostly look at high gear, since the A/F vs RPM error is going to be greater in lower gears due to the RPM increasing so much faster. And, I assume, if you leave off a 2 step, that your launch A/F looks much leaner due to the misfires caused by the 2step. Misfires put more oxygen in the exhaust, and our Wide Band O2 sensors calculate the air/fuel ratio by oxygen content.
I hope if you already knew all this, I didn't offend you. Maybe somebody did not know. Not trying to be a know-it-all.
Ed Wright 4156 SS/JA |
Liked 887 Times in 239 Posts
Just looked at my first run here at RT66 , my RacePak O2 is .021 behind RPM
#9 | |
Thanks Tom! Quite interesting what you are seeing. Bob Shaw and Bob Gullett are seeing .2 seconds and you are seeing ,02 seconds. Do you have any logic about why you are seeing so much less delay?
