#11 |
Liked 39 Times in 9 Posts
C-11 makes the most power with my combo (dish 305). Tried them all!
Reggie Winkles 2650/Stock |
#12 |
Liked 68 Times in 26 Posts
I’ve used mainly C12 (now using supreme Sunoco) and it always worked well in my p/sa 94 caprice 265 car... I never tried c11...
Mike Epprecht 94 caprice P/SA - SS/PA 265 |
#13 |
Liked 456 Times in 148 Posts
I have (4) 5 Gal cans of C 11 that were purchased in Boise. If there's a Div 6 or 7 stock racer needing C11 for Mission or Woodburn I could have the fuel there. All 20 gals 300.00 $
Steve, 6380 STK. 206 799 1544 |
#14 |
Liked 184 Times in 113 Posts
If you have to mix fuels because of availability.
Are there any issues? Can you run pump unleaded gas with the race fuel and be ok? Dan |
#15 | |
So in answer to your question, no.
#16 |
Liked 254 Times in 78 Posts
I run Sunoco Standard- 110. Ran some Sunoco Supreme- 112 and slowed down a .1 in eight mile. Tried the new Sunoco Surge (105) at bowling green, seems like it picked me up but have not done back to back and weather was a factor. Dished piston 305 2 barrel.
Mike Moller NHRA 203 Q-R-T/SA |
#17 |
Liked 33 Times in 16 Posts
That happened to me at last years SportsNationals. I did not fail, but was noted it was flat. Tech offered to check my jug, but I remembered what had happened then over the winter when some non-ethanol was mistakenly poured in the cell.
Rich Taylor I/SA - 321 |
#18 |
Liked 1,955 Times in 590 Posts
Mixing fuels at an NHRA race is a No No. It will surely get you disqualified. Best is to always run the same fuel. I make sure I have enough fuel with me at all times. You cant always be sure to get what you need at the track. If you have to change for some reason make sure you drain the tank completely and then flush a bit of the new fuel through the system. This is the reason most run a small fuel cell in their cars. Makes it much easier to control the fuel issues.
Mike Pearson 2485 SS |
#19 | |
Have an 8 gallon tank made and will install later. Need to add a drain. The warning about mixing fuels. Does that include mixing Sonoco, VP dissimilar rating approved fuels? Dan |
#20 |
Liked 312 Times in 175 Posts
Dan: Don't mix fuels, even if the colour is off they will fail it.
