Old 03-19-2018, 10:35 PM   #171
6130
Liked 117 Times in 50 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Jeff Stout View Post
After having the flu twice in January and February I had to build from scratch a 565 blower motor for a friend. Installed in his car last week and no problems. Oldsmobile is on the ground and taking care of everything under the hood before dropping motor in. If anyone is reading I need arm off a vega steering box. I thought I had 2 but the spline is the wrong size
Wow. Take care of yourself. When I was 18, the flu didn't slow me down much, but at age 55, this last bout knocked the poop out of me- I was flat on my back in bed for three days, and felt like I was gonna die.
Old 03-19-2018, 11:15 PM   #172
Jeff Stout
Liked 706 Times in 283 Posts
Originally Posted by FED 387 View Post
New on EBay $23 free shipping Fed 387
Thank you. I will order Tuesday.
Old 03-24-2018, 06:18 PM   #173
Jeff Stout
Sawzall, cut wheel, hammer and a Saturday afternoon and progress
Old 06-18-2018, 05:54 PM   #174
Jeff Stout
Some updates as Im getting close
Made alternator bracket out of scrap metal. 84 amp Alternator in car and works. Had large pulley on shelf
Using Ford relay just for junction to connect positive wires to and to use as a remote starter button. Found on shelf
Fuel system missing sample valve, but otherwise done
Front wheels mounted and balanced. Found new steel stems on shelf $20
New brake lines and some fittings $39
Steering arm $43
Double post style battery $45
I had all the braided lines new on shelf with fittings and old regulator from nitrous days. The rest of gauges were from another car that has a data logger and are all wired in. Playback tach and shift light wired.
Total $7933.98
Old 06-18-2018, 05:56 PM   #175
Jeff Stout
Old 06-18-2018, 06:05 PM   #176
Jeff Stout
The office. Ergonomically placed. Wiring all done just need to tidy up
Old 06-18-2018, 06:48 PM   #177
Nmbr1GMfan
Getting close!
Todd Greene
Old 06-18-2018, 09:47 PM   #178
Jeff, You've got a coil under that cap??
Old 06-18-2018, 10:03 PM   #179
Jeff Stout
Yes, I did a Pertronix ignition.
Old 06-18-2018, 11:49 PM   #180
I'd get it out of the cap and get an oil filled Blaster or something and mount it where it will stay cooler.
