Old 08-15-2018, 10:06 PM   #11
MIKE JONES 302
Liked 85 Times in 15 Posts
Default Re: 302 Chevrolet Engine Build
Originally Posted by Casey Miles View Post
Why are you starting with a 2 bolt main block, 302 came with 4 bolt? The original blocks where 618 castings in '69. I'm not questioning your build, just pointing out different items, but in 1966 maybe they used 2 bolt blocks.
Also, if you are using an older block be sure to test the walls for pin holes. I personally got burned by the pin holes twice.
Casey Miles
69 Z/28
My build is a 1967 302, which did use a 657 2 bolt block as I have, my heads are also 462s the only difference between my block and an original 302 block is the code on the deck. I did sonic ck my block after cleaning, I think it will be ok, hoping for 400 HP on the dyno.
MIKE JONES 302 is offline   Reply With Quote
Old 08-15-2018, 10:28 PM   #12
MIKE JONES 302
Pictures of rods. I will balance them next.
ID:	46577   Click image for larger version
ID:	46578   Click image for larger version
ID:	46580   Click image for larger version
Old 08-15-2018, 10:40 PM   #13
MIKE JONES 302
Originally Posted by Nmbr1GMfan View Post
Very cool build.
Thanks!
Old 08-15-2018, 11:27 PM   #14
MIKE JONES 302
Setting up for the line hone.
ID:	46582   Click image for larger version
ID:	46583   Click image for larger version
ID:	46585   Click image for larger version
Old 08-15-2018, 11:35 PM   #15
Nmbr1GMfan
Nice progress.
Todd Greene
Old 08-17-2018, 10:50 PM   #16
killintime6968
Liked 91 Times in 29 Posts
Are you building for street or strip ? Higher quality rods would be a good idea. I have spun my Original 69 Z28/RS to 7200rpm on many occasions, but that is playing with fire. On one of my 302 engines in my Super Stock car I have spun it too well over 9000.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 09-03-2018, 08:19 PM   #17
MIKE JONES 302
Today I finished my line hone, set housing bore to 2.4914. Next I will clean the block and set up for decking, assembly height:
Stroke 3.00
Rod length 5.698
Comp height. 1.800
Total height. 8.998
I need to decide which head gasket thickness I will use, then I will cut the block.
ID:	47053   Click image for larger version
ID:	47054   Click image for larger version
Old 09-03-2018, 09:20 PM   #18
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Thumbs up Re: 302 Chevrolet Engine Build
Mike Jones you are doing a fine job, keep the Build updates coming. It's great to see a young fellow developing an ability. Your combination of parts should workout just fine, keep it light and low drag. The preparation of all the components are important, but you appear to have that handled. Keep up the "GOOD WORK"… Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 09-03-2018, 09:47 PM   #19
MIKE JONES 302
Thanks! A member on here donated this 1967 small journal Z/28 windage tray, which was very appreciated, very hard to find piece. I will clean it and punch the holes out.
Old 09-03-2018, 10:23 PM   #20
Nmbr1GMfan
Very cool! Lots of great members here that's for sure.
Todd Greene
