Old 09-11-2018, 10:55 PM   #1
Superstreet29
Liked 4 Times in 4 Posts
Default When do you shift
Just curious, when do you go on the stop, when do you shift and what rpm do you cruise at. Just wondering how many different set ups people use
Superstreet29 is offline   Reply With Quote
Old 09-12-2018, 10:03 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: When do you shift
My car is slow, so to get it rolling I go on the stop at 0.500. Cruise at 4200 (RPM set in the pits. I don't know what RPM it actually cruises at on the track). Off the stop somewhere around 1.600 and shift by hand at 7000 rpm.
S/ST 51
S/C 53
Old 09-12-2018, 02:25 PM   #3
Superstreet29
I go on TS at .08, cruise at 4200 and shift at .40. 10.90@138
Old 09-16-2018, 08:20 PM   #4
Shake & Bake
Liked 37 Times in 33 Posts
I go on the stop at 0.001 and coast at 4150, shift at 0.30, 9.90@183
Shake & Bake is offline   Reply With Quote
Old 09-17-2018, 02:56 PM   #5
Gary Federico
@ 2850 Lbs on the stop at .000, shift .75, 4200 stop rpm, between 3.75 & 4.25 sec. in the stop. 10.90@152
Gary Federico 1814 SST
Gary Federico is offline   Reply With Quote
Old 09-17-2018, 05:16 PM   #6
Keith 944
Keith 944's Avatar
I’m not saying, But its somewhere between zero and 10.90. 😆
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 09-17-2018, 07:06 PM   #7
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: When do you shift
Right before the holes appear in the oil pan !
Old 09-17-2018, 08:27 PM   #8
Superstreet29
Do you shift that far out to make the 60’ more consistent?
Old 09-18-2018, 04:04 PM   #9
Gary Federico
The transitions were smooth & that's what I looked for. But Keith has the inside stuff, he just doesn't share as well as play well with others on the 1320.
Old 09-18-2018, 09:07 PM   #10
Superstreet29
When I had my big motor in the car I could go on at .001 and shift at .20 and it was consistent. When I put the 467 back in, it seems to struggle sometimes shifting that early and the 60s aren’t consistent. The farther out I move the shift with this motor, the more consistent it seems to get. I think it knocks the breath out of this smaller motor when the air is bad. That’s why I was curious
