Old 09-17-2018, 08:58 AM   #631
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
[QUOTE=HandOverFist;572964]I believe this is the one I am using on the Camino... https://www.jegs.com/i/Aeromotive/027/13304/10002/-1
Rich, I don't think this is a regulator issue per se, These huge volume pumps will over run the regulator if the return side is inadequate. I believe I made a mistake and should have run a -10 return instead of a -8. This fuel system is overkill x10.
Todd Greene
Old 09-17-2018, 03:38 PM   #632
Nmbr1GMfan
Originally Posted by Dissident View Post
Sirs and Ladies,
Inside a small pressure gauge can be a scary exposure to dangerous possibilities for race cars or any vehicle that vibrates. The flimsy Bourdon tube is very thin and filled with fuel. If vibration cracks it, a leak occurs, requiring an adequate fire extinguisher immediately handy! I do not know why NHRA still allows these things used on fuel systems under the hood.This comment to you all is only meant as a SAFETY advisory and not intended to hijack the thread, but it seems to me that it is salient in that we have all followed this build with interest and Autumn and so many others deserve the best and safest route to their best experience on the racetrack.
Now you can return to the regularly scheduled programming.
Regards,
HB2
Dissident
HB2, Is this the safer setup?
https://www.autometer.com/2-5-8-fuel...ak-valley.html
Todd Greene
Old 09-17-2018, 03:58 PM   #633
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
[QUOTE=Nmbr1GMfan;572982]
I was just wondering what the rated psi range is for that regulator.
Probably one of the safer alternatives is to mount the gauge outside of the engine compartment like the Camaro. Handy to verify pressures as well while making a pass.
Rich Taylor
I/SA - 321
Old 09-17-2018, 04:23 PM   #634
Nmbr1GMfan
[QUOTE=HandOverFist;573019]
Rich, the pressure window is 2-20 for the regulator. Honestly, I may take the underhood gauge off and plug that outlet after the initial running. We are adding a racepak at the end of the year and will log fuel pressure.
Todd Greene
Old 09-17-2018, 04:53 PM   #635
FED 387
Liked 333 Times in 180 Posts
I think that return line is a -8 -----you can adapt a -10 line to the -8 but you are still going thru a -8 outlet--FED 387
Old 09-17-2018, 10:48 PM   #636
Nmbr1GMfan
Mine is a -10, I adapted it to an -8.
Todd Greene
Old 09-17-2018, 11:42 PM   #637
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Todd,
Here is a suggestion before re-plumbing the return. Disconnect the return line at the regulator and place a short section of hose in a fuel jug below the regulator. Plug the return line going to the fuel cell. Run the pump and check the regulator pressure. If no change then the return line size is not the problem. Have you increased the regulator setting and backed it back out? Did it change pressure? Chances are it's something else and not the return line size.
I run an Aeromotive A1000 pump, Supply is -10, return -8. With my carbureted stocker it had no issue being able to bypass fuel and maintain 7 PSI with the engine not running.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-18-2018, 08:29 AM   #638
Nmbr1GMfan
Originally Posted by Sean Marconette View Post
Todd,
Sean
It's already all apart so we will soon see. I think the flow rate between the two pumps (A1000 - A3000) is significant enough to assume an -8 isn't ideal here (I've used a -6 return with an A1000 @55psi 1:1 boost referenced). I also know a restrictive return will cause this, and I have yet to find any other issues in the system.
Todd Greene
Old 09-18-2018, 01:18 PM   #639
Dissident
Liked 73 Times in 36 Posts
Please indulge me as I have some questions about this by-pass return type fuel system.
What is the pressure from the pump to the regulator? This would be called the "system pressure" and that would oppose acceleration of the vehicle.
Looking at your plumbing, I was confused on the connections. Looks to me as if the thing is not correct, but I may be totally full of soup.
Thanks in advance.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 09-18-2018, 04:33 PM   #640
Nmbr1GMfan
Thanks in advance.
Regards,
HB2
Dissident
HB, I do not know what the pressure is to the regulator, haven't checked it. I know the regulator is confusing, I also second guessed it. The front middle -10 connection is the inlet, the -10 connection on the bottom is the return and the four -8 connections on either side of the inlet are the regulated outlets.
Todd Greene
