#11 |
Liked 4 Times in 3 Posts
probably need to drop the gear from a 488 to a 56 if i went the quarter stroke route. the heads i have now are around 325 cc older brodix castings that flow 370 and 310. they are in excellent shape but im sure i would be leaving a bunch of power on the table if i used them but consistency is the game so i bet with the right cam using all the old stuff would work fine. prob make 950 and a bunch of torque. i know that speed doesnt nec win races but being a little closer to the 150 plus guys would help me judge closing distance a little better
#12 |
Liked 759 Times in 379 Posts
I'll take big bore/short stroke over the other way around everyday. My 522 4,560 bore/4.00 stroke makes 947HP with a 4150 carb atop it's small plenum manifold in my 3150 lb. Firebird. The plan is to run S/ST next season and I expect 150MPH on the stop.
#13 |
Liked 7 Times in 4 Posts
[QUOTE=gnicholson;574346]Right now I have a very consistent car in the 60 and im extremely happy with how the car drives. i can fab another set of headers if i need to just trying to keep it simple. i definitively agree with staying on the small side with pri tubes.
[QUOTE] If the car is very consistent why are we making changes? Is the engine worn out or do you just want to go faster? |
#14 |
mostly i would like the car to be faster. i dont have to be on kill but 142 to 45 would work
#15 |
Liked 23 Times in 15 Posts
I feel your pain Gary. However I keep reminding myself that a dial-able and consistent car will win more rounds. I sure do get tired of those cricks in my neck from looking behind me though, lol.
Let me know what you end up with. Maybe you can save me a few thousand dollars trying different stuff... |
#16 | |
Liked 134 Times in 70 Posts
#17 |
^^^ true that. man that car is deadly
Back to the original post I have won just as much in a slower car as I have being the faster car but given a choice I would always prefer to be faster
#18 |
I had the same 505 combo in my S/G Camaro. I went with a 4.500 bore with the rest of my parts in the new block. It is a 540. The increase in bore size and the 4.250 stroke work great. I picked up 6 MPH on the stop. HP on the 505 was 835 and the 540 is 870. This is on a tight dyno with real numbers. I would buy pistons and a block and call it good. Some flow bench time dont hurt and I ran mine up to 14.8 from 13.2 for compression.
#19 |
6 mph is a good gain. it had to have picked up more than 35 hp
#20 |
Liked 4 Times in 2 Posts
Certainly you don’t need to be fast to win....but if you’re buying new parts....you should probably make it big as you can afford...you can always de tune it....
I may not be a good example...lol |
