#11 |
Liked 100 Times in 51 Posts
I wonder about this also. If we have a car that runs SG, 9.90 @ 160ish. If the stop stall is
4200 for 3.5 seconds. How fast is the car at 4200 for the 3.5 seconds? Lets just say it's 130 mph and then gets to 160 at the finish. If the same car is 4000 rpm for 2.5 seconds. Is that car now running 125 mph. Does it get to 165? The car is at a slower speed and has more time to accelerate, but can it over come the lower rpm while on the stop to run faster at the stripe? Or, is it better to be at a faster mph on the stop and not have as much mph to gain? I have heard many discussions about this but I'm still not sure which one is better? Dan SC4698
Dan Foley SC 4698 |
#12 | |
Liked 431 Times in 224 Posts
If two identical cars go on the stop at the exact same time, the one with the lower cruise RPM should have more top end MPH. My personal guidelines are: 1. The 'stop on' time should be just high enough for the car to cut a light. 2. The cruise RPM should be set so that the car can at least clear the 60' beam while on the stop every pass in any weather conditions. There will be other things to consider in each case. Some cars may need to be WOT a little longer at the start to work the chassis properly. Some cars may come off the stop cleaner with a little higher 'stop on' RPM than absolutely necessary. I run oddball combinations in both of my cars, so I can't always use these principles but I use one of them in each car.
S/ST 51 S/C 53 |
#13 | |
S/ST 51 S/C 53 |
#14 |
Liked 10 Times in 2 Posts
That had me confused as well. I don't remember exactly, but I believe my datalogger showed MPH on the stop at just over 60mph. And my cruise RPM is on the high side.
#15 |
Liked 4 Times in 3 Posts
my car with a 4.88 and 32 inch tire shows about82 mph at 4200. drop to a 4.30 would be about 93 doing the basic rpm tire diameter gear ratio calculations. ofcourse thats with no convertor slippage so its actually less
#16 |
My completely uneducated guess would have been 40-60 mph for most cars.
S/ST 51 S/C 53 |
#17 |
Liked 26 Times in 12 Posts
Mine is probably slower than that since my cruise is 3,600 rpm's
#18 | |
Dan
Dan Foley SC 4698 |
#19 | |
My dragster is mechanically injected, so I go on the stop at 0.100 and shut it down to a dead idle. My cruising speed is almost a stop. I also come off the stop in Low gear. I've never run this combination wide open to the 1/4 but I only lose 2-3 MPH at the 1/8 mile when running 8.90 on the stop as compared to a wide open pass. 6.19 @ 145.86 compared to 4.69 @ 148.14. I would hazard a guess that cars running a more traditional cruise RPM and coming off the stop in High gear are down 10+ MPH at the 1/8 compared to a WOT run.
S/ST 51 S/C 53 |
#20 |
Liked 4 Times in 4 Posts
I do know if you are low on power dropping that cruise rpm gets unpredictable. And if you make good power getting it too high puts too many numbers in the timer. It’s a test and tune fine tuning point til you find what works on your car. I’ve been on at .001 with a Maxspeed, on at .10 same carb...you just have to have enough power to do it that soon or it will know the breath out of it and you’ll get a dip. I had a big motor combo that liked .001 and shift at .020.at 4300 and it worked well. Tried it with a smaller motor and it was a no go
