Old 01-18-2019, 11:42 PM   #861
Liked 5,138 Times in 1,961 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
Do any of the manufacturers actually stock any approved pistons for these things?
No. Not the good ones. 6-7 weeks out anyway.
What do you have now? How are you on the assembly weight?
Stock block, no fill, @ .070? Not liking the sound of this.
Might be better off doing a new block, or maybe 8 nice, thick sleeves.
Old 01-19-2019, 08:51 AM   #862
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Stock block ? Filled ?
Old 01-19-2019, 09:20 AM   #863
Alan Nyhus
Liked 799 Times in 236 Posts
Todd, you might check into the Line to Line coating system for your existing pistons. It works. -Al
https://www.line2linecoatings.com/
"That'll never work....."
Old 01-19-2019, 09:29 AM   #864
Billy Nees
Todd, put a block around what you have to get the car out and start on a new bullet! At some point in time, you're going to want a spare so just start with your spare.
Billy Nees 1188 STK, SS
Old 01-19-2019, 09:45 AM   #865
HP HUNTER
Liked 373 Times in 129 Posts
Alan, A block is inexpensive, I don't particularly like the current block casting as well. This is a perfect time to start with a virgin block and fix any and all machining problems that exist, now that is if the piston skirts are not collapsed. Think of it this way.......the hard part of the car build is is past you.
Now lets take a look at the valve guides and the valve job?
Old 01-19-2019, 10:16 AM   #866
Nmbr1GMfan
Mark, The pistons are Ross, I don't know the weight, filled block. Engine guy suggested a coating like line2line to at least get running. If I have to buy an expensive set of pistons I'm not putting them in this block for sure.
Todd Greene
Old 01-19-2019, 10:18 AM   #867
Nmbr1GMfan
Yes Glenn, stock block thats been filled. If I have to buy pistons I'll buy an aftermarket block.
Todd Greene
Old 01-19-2019, 10:22 AM   #868
Nmbr1GMfan
Al, I have a buddy here that has good things to say about Line2line, we have discussed this as an option. Someone here that has a supercharged hemi promod said his piston life doubled with this coating. This will be call #1 on monday, thank you.
Todd Greene
Old 01-19-2019, 10:26 AM   #869
Nmbr1GMfan
Billy, That was exactly the plan this year, start racing and at the same time build a brand new everything short block, transfer the top end and rebuild what we have currently for a spare. Well, we just had to take a dirt road detour but I think we will get there eventually.
Todd Greene
Old 01-19-2019, 10:37 AM   #870
Nmbr1GMfan
I agree 100%, the only problem is the possible 8 weeks for pistons, I'm not puting used pistons in a new block because I would like to run a really nice ring and I don't think these pistons will seal. If I can get this running with most of the current parts it will get us going to the point of starting a new one at a more reasonable pace. The heads look pretty good except for the spring fiasco that possibly started this whole mess.
Todd Greene
