Old 02-06-2019, 12:37 PM   #11
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Want to run 9.90
How fast does the car run wide open? That will influence the options you have. As Hacksaw mentioned, you can go all the way to High gear while on the stop, but you probably want to be a full second quicker than the index (say a 8.90 or quicker car when trying to run 9.90) to pull that off. I get the feeling that your car isn't that quick.
I've never run a 3-speed, but here's what I think I would do in your situation. I'd launch the car hard, then put it on the throttle stop. Have your shifter hooked to a timer which would put the car in 2nd gear shortly after the throttle stop turns on. When the car goes wide open again, I'd either have some way to put the car in 3rd based on RPM or just shift it by hand at the desired RPM.
S/ST 51
S/C 53
Old 02-06-2019, 12:39 PM   #12
jlundy
Originally Posted by Hacksaw View Post
What about getting it to shift to high gear when your on the stop? Wouldn't that be the most consistent? Thinking you would need a little down track speed but your really fooling the car to think it has a PG trans.
That could work. 1, 2 shift........On stop, come off in high gear. What kind of shock to the converter would that be if any?
jlundy is offline   Reply With Quote
Old 02-06-2019, 12:45 PM   #13
jlundy
To be honest I have no clue what it runs...........I run at altitude 4000ft. This is an all new combo 445ci SBF, C4 trans, 486 gears. 2260# with me in it.
Just fired the motor first time last Sunday while everyone was watching super bowl.
Old 02-06-2019, 01:25 PM   #14
drgrcr1156
Liked 2 Times in 1 Post
I've never run a 3-speed, but here's what I think I would do in your situation. I'd launch the car hard, then put it on the throttle stop. Have your shifter hooked to a timer which would put the car in 2nd gear shortly after the throttle stop turns on. When the car goes wide open again, I'd either have some way to put the car in 3rd based on RPM or just shift it by hand at the desired RPM.[/QUOTE]
I run a 3 speed TH400 in 9.90 and this is how I have my shifts set.
drgrcr1156 is offline   Reply With Quote
Old 02-06-2019, 02:09 PM   #15
pmrphil
Liked 348 Times in 152 Posts
Have you done the math regarding rear gear and tire size? As far as finish line RPM goes?
Phil Molski
PMR Performance
S/C 1623
Old 02-06-2019, 03:03 PM   #16
jlundy
Yes, I have and finish line rpm would be about 7600.
Old 02-06-2019, 03:13 PM   #17
Hacksaw
Liked 312 Times in 175 Posts
I think as long as you have some decent rpm and wheel speed on the stop the converter can handle it and recover quickly. Lots of PG racers do this now. Check with a doughnut maker and get there advice.
Old 02-06-2019, 04:26 PM   #18
jlundy
I would call Chris Continental but they are out of business.
Old 05-23-2019, 01:57 PM   #19
jlundy
Ok, so I made some passes and the car without any tuning or real testing is running 9.55 @ 140.21 @6200ft DA.
1-2 shift @ 1.8 secs and 2-3 shift @ 3.9 secs obviously short shifting some.
A-1 converters just built me a killer converter.
Super Gas adjusted index is 10.30 at my track.
I need to figure when and how long to put it on the stop now.
Old 05-24-2019, 11:19 AM   #20
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
Turn stop on about .2 then shift into 2nd about .5 and come off stop in 2nd and shift into third off RPMs
Ken MacNicol is offline   Reply With Quote
