#11 |
Liked 8 Times in 6 Posts
Evans will not make your vehicle run cooler, its just a legal fluid that won't freeze, rust and has a higher boiling point.
Class Racer Magazine Writer Super Comp A197 |
#12 |
Car has a Afco scirocco radiator/fan/shroud and a Meziere 55 gpm pump with 16 an hoses top and bottom. Had a 12 an hose from top of intake to top radiator and switched to 16 an and it did help with cooling the motor down a little faster but still can’t cool down very quick.
#13 |
Liked 759 Times in 379 Posts
1. that water pump needs a radiator with the same size inlet and outlet as on the pump.
2. what temp are you staging at? |
#14 | |
Liked 290 Times in 147 Posts
I understand you may be space confined with your application, but I would see if I can get something larger than a 2'x1' Scirocco rad. I honestly didn't even know those things were still being used outside of dragsters and altereds. |
#15 |
I try to roll into the water at 110 and leave the line at 140 and go through the lights at 170 +. Car does have double pass radiator. Talked to Meziere they told me to use the 12 an on top and 16 an to slow the water flow down. Both Afco and Meziere said this should have no problem cooling off after a pass.
#16 |
what's in the radiator now?
#17 |
Water and Purple ice
#18 |
get the purple ice out
#19 |
Why?
#20 |
it's a coolant, coolants don't cool and it also has a reputation for eroding aluminum.
