Old 03-24-2019, 12:53 PM   #1101
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Glenn Briglio View Post
Might want to start with oil restrictors with .060 hole in them on engine stand and prime engine to see results up top.You can always make the hole bigger.
That's the plan Glenn, thank you.
Todd Greene
Old 03-24-2019, 01:08 PM   #1102
Kenny McCoy
Kenny McCoy's Avatar
Liked 5 Times in 3 Posts
I would start at .030 with thin oil
Kenny McCoy is offline   Reply With Quote
Old 03-24-2019, 04:25 PM   #1103
Dissident
Liked 73 Times in 36 Posts
Todd, Autumn, and those interested,
FWIW - All my calculations, estimates, and comments were based on the kinematic viscosity of hot (190F-200F) 30W oil. The leakage flow with lower kinematic viscosity would be higher numbers.
Being an oil patch brat, I have rather strong opinions against using 0W lubrication in engines as I was taught to err on the side of reliability. And I fully realize your experiences may vary, but you can't win if you don't finish.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 03-24-2019, 04:59 PM   #1104
Nmbr1GMfan
Or never get started Thanks for the insight.
Todd Greene
Old 03-24-2019, 09:24 PM   #1105
Nmbr1GMfan
Spent a few hours scraping gaskets and cleaning parts today. Additionally, here's a picture of a piston with the Line2Line coating after some dyno time.
Todd Greene
Old 03-27-2019, 08:16 PM   #1106
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I'll just throw my 2 cents in.....
A few more points of internal engine oil leakage are the rod side clearance, if the rear main has had the split chamfered for more oiling to the thrust faces, cam bearing clearance, seal between the oil pump mounting surface and the cap, oil pump body to cover leakage and gear end play.....
Do you monitor the oil pressure at the front of the block or the rear?
A bad oil filter bypass valve doesn't vent to the pan it just bypasses the filter...
Bob Mulry 7516 STK
A & M Motorsports
Old 03-28-2019, 09:58 AM   #1107
Nmbr1GMfan
Rear. When I'm done I'll check it at both.
Todd Greene
Old 03-28-2019, 10:04 AM   #1108
Nmbr1GMfan
Pistons are off and rods are ready to be checked.
Todd Greene
Old 03-28-2019, 12:23 PM   #1109
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Are you doing this rebuild before those bottles were emptied..........j/k
Old 03-28-2019, 06:06 PM   #1110
Nmbr1GMfan
After this deal, I'll be drinking for sure.
Todd Greene
