Old 04-11-2019, 10:24 AM   #1
Maxie fury 64
Default Lightweight batteries
Wanting others opinions and experiences. Bought a Braille lightweight battery beginning of last season. The 17lb model.
Worked fine for most of the season but by the end of the year it left me stranded at fuel check a couple times. Just doesn’t have the same power it did at first. Are the odyssey batteries any better and last longer or any other brands?
It’s a stocker, six pack car. Any insight would be appreciated,
Maxie fury 64 is offline   Reply With Quote
Old 04-11-2019, 10:42 AM   #2
RJ Sledge
Liked 288 Times in 90 Posts
Default Re: Lightweight batteries
Check alt output, install volt meter, should read at least 13 volt, larger crank pulley and make sure belt doesn't slip, keep the battery charged up between rounds. Small East Coast Elec mini was a good choice for me.
I've run the 9lb and the 21lb, always a problem with the 9lb at scales, switched to 21lb and really never had a problem.
watch your battery usage before and after run while waiting at scales. run the pump/fan for short periods intervals (2 minutes) and then let it sit for a while, do it again. Leaving it on for more than 5 minutes just puts drain on battery voltage.
Good Luck
RJ
RJ Sledge is offline   Reply With Quote
Old 04-11-2019, 10:54 AM   #3
e vassar
Liked 271 Times in 107 Posts
What RJ said about the east coast alt it's a good one. I did try a braille batt a few years ago.after almost a whole season of bracket racing,my opinion would be the battery and charger are not durable enough to hold up to life in a race car,especially an F. I. car. Your not going to be excited about how light it is when you're car wont start in the semis.
Old 04-11-2019, 11:33 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Like RJ said, the East Coast Ultra Mini is my first choice for all the Stockers I build.
You might want to check out Anti Gravity Batteries . Their L Ion batteries are very dependable .
One other thing I would check is the master disconnect if you have one . ... I've seen several in the last few years that developed high resistance after a few minuets of use resulting in a voltage drop. Many of the older and a lot of the newer switches are only rated at 25 - 30 amps continuous .
Old 04-12-2019, 07:57 AM   #5
Rsmith38
Liked 28 Times in 15 Posts
The lighter batteries (the powersports and Breiles are made by East Penn) work but will leave you stranded at the scales or other spot sometime. I finally went with a 450 amp 30 lb battery - It starts every time. I don't have a weight problem and the 10 lbs difference has no effect on ET.
Rsmith38 is offline   Reply With Quote
Old 04-12-2019, 08:12 AM   #6
Liked 10,712 Times in 2,230 Posts
I use two 11# Braille use 2-3 years then replace. My alternator works. Always check connections for being tight.
Old 04-12-2019, 08:31 AM   #7
curtis reed
Liked 125 Times in 59 Posts
Are you guys keeping a battery tender on them in between races? If not I believe you really should. I'm only a bracket racer and I do run a 55amp alternator but my battery gets lots of abuse from the amount of times I start the car at double race days many times making 10-14 passes a day. I never charge at the track either.
The last battery I had in the car was in there 8 years. It's still going on my trailer tongue running the jack and my trailer radio. I have a new Odyssey in it now going on it's 3rd year and it's the same exact plate design as the old one. Granted they aren't the small lightweight batteries but the tender on 24/7 when it's sitting keeps them topped off and de-sulfated so whatever battery you use will work better and last longer. Just my experience.
Curtis
curtis reed is offline   Reply With Quote
Old 04-12-2019, 10:09 AM   #8
Maxie fury 64
Thankyou for the advice, I’ll check into it
Old 04-13-2019, 12:55 PM   #9
Greg Hill
Liked 279 Times in 68 Posts
We use two of the Odyssey batteries that weigh around 25 lbs. each plus run a East Coast small alternator. I think this is year 4 coming up on the batteries. No problems.
Greg Hill 4171 STK
Old 05-27-2019, 02:32 PM   #10
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
4 Year full warranty!
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
