Old 04-23-2019, 08:17 AM   #1141
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by nickh View Post
Todd I have brand set of standard rod bearings child & Albert's that have been polydyn coated if you want them? They are free to you
Thank you Nick, I have a set now so I'm all good.
Todd Greene
Old 04-23-2019, 08:38 AM   #1142
Nmbr1GMfan
Originally Posted by Greg Reimer 7376 View Post
Every time I shut my cars down for any length of time after using C-12, I fog the motor. That means to fire it up, open the throttle with the engine running and put a couple ounces of Marvel Mystery Oil or even plain old ATF down the carb. When a puff of smoke appears out the headers,shut it off. The oily film prevents rust from appearing on the valve faces and seats and the cylinder walls. C-12 is a very dry fuel and it leaves metal surfaces unprotected from humidity in the atmosphere causing rust. I imagine Florida has more than its share of humidity year round.
I'm not sure I trust it. Rusty within a couple days inside an air conditioned building, I may just change fuel.
Todd Greene
Old 04-23-2019, 08:40 AM   #1143
Nmbr1GMfan
Originally Posted by Kenny McCoy View Post
C11 is faster, fog motor with WD-40 after engine cools down use starter button open throttle blades crank it over for about 10 seconds works good in Florida.
Thanks Kenny, I had been warned about it, didn't realize it would be this bad.
Todd Greene
Old 04-23-2019, 09:07 AM   #1144
Alan Nyhus
Liked 800 Times in 237 Posts
Todd, we see some rust issues with C12 if the engine hasn't been run for a while. C11 is a 'drier' fuel, for lack of a better term, so things can rust even quicker.
Fogging with Marvel Mystery Oil, ATF, Stabil fogging oil, etc. works well. -Al
"That'll never work....."
Old 04-23-2019, 10:15 AM   #1145
Nmbr1GMfan
Thanks Al, Keith Bennet warned me about it up front, I didn't fog it. I'll have to fog it or change fuels all together.
Todd Greene
Old 04-23-2019, 11:03 AM   #1146
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Sunoco fuels are better in that aspect.Petroleum based.Wd40 will dry up over a couple of months.
Old 04-23-2019, 11:05 AM   #1147
FED 387
Liked 335 Times in 182 Posts
we have used Marine type of aerosol Fogging never any problems---FED 387
Old 04-24-2019, 12:49 PM   #1148
Nmbr1GMfan
Caps are off the rods, rings on the pistons and hope to have the block and heads in the washer today/tomorrow.
Todd Greene
Old 04-24-2019, 04:54 PM   #1149
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Cast iron heads rust very quickly and easily especially around the exhaust valves. All the after race smog techniques mentioned are good. One more that helps is to cap your headers at the collectors. The plastic caps used on threaded pipe works well if you can find a size that fits. Large Electrical conduit or black pipe sometimes has caps that fit. My buddy was an electrician foreman on big jobs and had those caps off his job sites.
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 04-24-2019, 05:50 PM   #1150
Billy Nees
I use styrofoam coffee cups.
Billy Nees 1188 STK, SS
