Old 04-24-2019, 07:43 PM   #1151
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: H-I-J '76 Nova re-fit.
We use nerf balls
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 04-24-2019, 08:20 PM   #1152
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Rich Biebel View Post
Cast iron heads rust very quickly and easily especially around the exhaust valves. All the after race smog techniques mentioned are good. One more that helps is to cap your headers at the collectors. The plastic caps used on threaded pipe works well if you can find a size that fits. Large Electrical conduit or black pipe sometimes has caps that fit. My buddy was an electrician foreman on big jobs and had those caps off his job sites.
Yes, the rust was everywhere but worse near heat, around the plug and exhaust valve.
Todd Greene
Old 04-27-2019, 05:50 PM   #1153
Nmbr1GMfan
Everything is cleaned, heads are back together, crank is in the block.
Todd Greene
Old 04-28-2019, 04:32 PM   #1154
Nmbr1GMfan
Rods and pistons are in, heads are on, studs and guide plates are in.
Todd Greene
Old 04-29-2019, 10:28 AM   #1155
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
After awhile you'll notice main cap walk even with studs.Only cure is 4 bolt mains.
Old 04-29-2019, 11:51 AM   #1156
Nmbr1GMfan
My initial plan was to use this one as a spare, at this point I'm wondering if it will ever run long enough to even be that.
Todd Greene
Old 04-29-2019, 07:26 PM   #1157
Nmbr1GMfan
Pickup to pan should be a max of 3/8".
Glenn, I'm also moving the pickup. This is how it was, nearly 3/4.
Todd Greene
Old 05-02-2019, 08:37 PM   #1158
Nmbr1GMfan
Ran for parts today and made it to this point, tomorrow starts the search for the perfect lifter/restrictor combination.
Todd Greene
Old 05-02-2019, 11:16 PM   #1159
HP HUNTER
Liked 373 Times in 129 Posts
DO NOT try to restrict the oil with the pushrods, that will not work. It must be done through the lifters.
Old 05-03-2019, 08:33 AM   #1160
Nmbr1GMfan
What's the difference? seems like the end result would be the same.
Todd Greene
